1983 civic wagon bogging issue
I recently acquired an 83 wagon, with a few issues.
It won't idle consistently and bogs down when under a load. Will run fine when accelerator is pushed to well above idle but when attempting to drive bogs down and dies.
The only things done so far are to spray carb cleaner which helped some. I plan to drain the tank and put in fresh fuel and a new filter. I also plan to replace the vacuum lines with new ones.
Future plans are to flush the cooling system, replace hoses, new fluids, put a new thermostat in, and change all of the belts.
Any other thoughts or ideas I should try? I am not ruling out a carburetor rebuild eventually but would like to avoid it if anything simple comes to mind.
Forgive my newbness, it has been a while since I fooled with a carb'd motor. Any other suggestions to be on the look out for?
Also anyone know of a good source for rear window regulators and any how to's for fixing the door lock mechanisms?
Thanks in advance.
Thanks in advance.
The carb on these cars are an EPA inspired nightmare and not many are successful at repairing them. I'm lucky, (I have access to a father/son team that only works on Hondas), in that I had a couple repaired fairly well. Even so, they hate to work on them.
I think that the ultimate and simplest cure is the Weber conversion that gets rid of all of the vacuum lines. They are available on eBay and will set you back at just over $300 but the result is better performance and some say even better gas mileage.
I drive an '82 Civic DX auto every day and a Weber is in my future...
I've long lusted for a wagon but they hardly ever appear in these heeyah pawts. Some day maybe...
dlx111
Dec 29, 2017 04:11 PM
civiclxb16a
11
Apr 27, 2005 06:20 PM
maxxdout
Jun 21, 2002 06:04 AM
