ls vtec problem HELP
someone help me out here ibuilt a ls vtec b18c1 head and block gsr cams itr pistons itr mani cranks and runs fine it warms up to normal temp a lil faster than before and wen it warms up its like the crank gets binded up and shut off if u tried to recrank it motor wont turn over till it sits for a minute and cools anybody know where i can start thanks
If you loved me, you'd all sell me your magic cards to me today
Please state what parts you are using exactly with good grammar and punctuation. It is very hard to understand that jumble of a sentence.
After you sort that out then please post what car this is in, what wiring harness you used, and what ECU you are running.
After that we can help you, until then we can not help you.
sounds like ur over heating and seizing the motor up.. the motor is not going to last long if u continue. your fans are not coming on and or ur coolant temp sensor isn't reading correctly.
