Anyone know a trusted mechanic in NYC to clean EGR ports?
Old May 28, 2013 | 09:00 AM
sonicjai's Avatar
Default Anyone know a trusted mechanic in NYC to clean EGR ports?
I have the dreaded CEL P0401 EGR insufficient flow on my 99 Prelude. Had the valve cleaned out twice but still came back on after driving 20 miles each time. I think it's definitely the EGR ports from reading other posts made about this issue. I have 133k miles on the car and doesn't seem like those EGR ports were ever swapped so it must be massive carbon build up in there.
Does anyone know a good mechanic in NYC that knows how to clean out the EGR ports on my Prelude? If so, how much are we looking for this job as well?
Any feedback would be greatly appreciated.
Thanks.
Old May 28, 2013 | 09:28 AM
Sparksman's Avatar
Default Re: Anyone know a trusted mechanic in NYC to clean EGR ports?
Clean it yourself, just take off and spray with some brake cleaner, or sensor/electrical cleaner. Thats nothing thats worth taking to a mechanic and forking over alot of money for. Ive seen a few threads on how to clean, I just took mine off and deleted it. Unless you "need" it its not necessary for a working car. Although fyi to delete you will need to have ecu adjusted for not having one, I just deleted all my emissions at once.
Old May 28, 2013 | 10:16 AM
friutoftheLude's Avatar
I cleaned mine out a few weeks ago, it was pretty easy...... There is a write-up on it step by step here somewhere
What i did was drill small holes just through the ports, screwed a screw thats big enough to catch and hold, then all i did was use the back of a hammer to pry the ports off
then go buy a gun/rifle cleaning kit and some carb cleaner and go to work, remember some of the holes should meet eachother too, and clean out the passage FROM the egr port itself too, that is forgotten sometimes
Old May 28, 2013 | 10:22 AM
sonicjai's Avatar
What am I taking off? Just the ports themselves? Although I enjoy working on my car, I am just a bit weary on doing this task myself and would rather let my mechanic take care of it this time around.
When you drilled small holes and inserted those screws that would 'bite' and hold, was it really hard to pry off with the back of a hammer? I was thinking of this too instead of getting a slide hammer as I have read some posts on how to do it yourself.
Also, did you get the port cap replacements from Honda directly or did you use something else aftermarket?
I'm hoping once this is cleaned out, this damn EGR CEL goes away.
Old May 28, 2013 | 02:39 PM
Here's the write-up:
http://www.preludepower.com/forums/s...d.php?t=275440
Sorry, its from preludepower
Old May 28, 2013 | 05:27 PM
bama01lude's Avatar
Here's a video from prelude zone:
http://www.preludezone.com/diy-engin...rts-video.html
If that doesnt work here is the direct link:
Old May 28, 2013 | 06:26 PM
flyrod's Avatar
Change to a P28/30/72 ECU and ditch that stuff.
Old May 28, 2013 | 11:17 PM
Sparksman's Avatar
^^^ This, its what I did.
95_DB7
May 2, 2013 02:16 PM
Secret Chimp
Nov 3, 2007 04:56 PM
