People running Skunk2 IM on Boosted B18B. Was it worth it...?
Old Oct 23, 2002 | 05:30 PM
JV's Avatar
JV
Who?
Default People running Skunk2 IM on Boosted B18B. Was it worth it...?
I recently purchased one of these for a very good price and wanted to get some info from people actually running this setup...
What are the pros and cons of this manifold?
Did it make much of a difference?
Any problems during or after install?
TIA, Jay
Old Oct 23, 2002 | 06:31 PM
Midwestrider's Avatar
Default Re: People running Skunk2 IM on Boosted B18B. Was it worth it...? (JV)
Ask Mase, he had a Skunk2 IM on his turbo LS.
Mase posted his dyno sheet here: https://honda-tech.com/zerothread?id=309285
Hope that helps
Eric
Old Oct 23, 2002 | 06:47 PM
Mase's Avatar
Well to answer your questions. I dont know how much of a difference it made because I installed the Skunk2 IM before i installed my turbo kit. However, I believe one of the reasons I made such good numbers on the dyno, is because of this Intake mani. Chris (DIRep) has a skunk2 waiting to be installed, hopefully he will dyno afterwards and we can see the difference.
Installation wasnt that bad. Its kinda a pain in the *** to get to the lower bolts holding the Intake mani to the head, but its not bad. Had to take both intake mani's to a machine shop and have them transfer the throttle body studs and fuel rail studs......
also, on the skunk2, there is an extra spout for coolant, i had to ghetto rig up a way to block it, so i just attatched a hose w/ a bolt at the end....hehe hasnt leaked a drop!
Other than that, the only thing i can tell you is, the skunk2 im doesnt have a bung for the evap sensor, but that isnt a big deal.
If you have any other questions, hit me up on AIM - SCMGatorEngineer, or you can send me a PM.
Old Oct 23, 2002 | 07:29 PM
highmilehatch's Avatar
Default Re: People running Skunk2 IM on Boosted B18B. Was it worth it...? (Mase)
What kind of numbers did you make?
Old Oct 24, 2002 | 12:52 AM
Mase's Avatar
Default Re: People running Skunk2 IM on Boosted B18B. Was it worth it...? (highmilehatch)
270 hp / 229 ft/lbs
Old Oct 24, 2002 | 01:31 AM
turbo Si's Avatar
My future License plate: I0WNART
That's funny!
Old Oct 24, 2002 | 01:32 AM
Mase's Avatar
Default Re: People running Skunk2 IM on Boosted B18B. Was it worth it...? (turbo Si)
That's funny!
HEHE
Old Oct 24, 2002 | 02:40 PM
JV's Avatar
JV
Who?
Thanks guys...
Old Oct 24, 2002 | 02:42 PM
Mase's Avatar
no problem
Old Oct 24, 2002 | 03:30 PM
DIRep972's Avatar
Smarter than you
by looking at the skunk2 vs. the stock LS manifold visually you would think it will make a big difference. the plenum is larger and the runners are shorter. the runner angle is better too. I cant wait to get mine installed and do a dyno comparison. Mase made 4hp less then me but it took him 8lbs less torque to do it. he was running less boost too. Im hoping for increases in both peak torque and hp from this mani. for 250-300$ I think it is a well worth it bolt on. hopefully ill have the comparisons soon.
Old Oct 24, 2002 | 03:50 PM
DRAGLS's Avatar
Default Re: People running Skunk2 IM on Boosted B18B. Was it worth it...? (DIRep972)
I noticed a huge difference after i installed the skunk2 IM car stopped hooking up in second&third gears
Old Oct 24, 2002 | 03:55 PM
W.Zero's Avatar
Default Re: People running Skunk2 IM on Boosted B18B. Was it worth it...? (DRAGLS)
the skunk2 manifold is a lot better then stock for sure but for the money you can get a JG IM for 300 and i think there a lot better then skunk2. but since you already got the skunk use that.
Old Oct 24, 2002 | 04:12 PM
boostedcvc's Avatar
Default Re: People running Skunk2 IM on Boosted B18B. Was it worth it...? (W.ZeroB18C1T)
What did the people with the skunk2 manifold do since there isn't a bung for the evap sensor. I'm assuming the evap sensor is the one on the top of the manifold. I already installed the mani on my engine thats sitting in the basement and thats the only thing that im not sure about.
Old Oct 24, 2002 | 04:21 PM
Speed PHreak's Avatar
Default Re: People running Skunk2 IM on Boosted B18B. Was it worth it...? (boostedcvc)
Skunk2 OWNZ on an LS. I installed mine prior to boost and noticed a dramitic increase in the midrange all the way up. I swapped out from a 91 auto IM, which has the EGR passages and just plain sucks. I"m sure it does wonders for my boosted engine also. No regrets about the $200 I layed down for a used one. Though, I can't see the point of getting another mani over this one. It works so well with the LS rev range I don't see why you would need any more flow unless you're on a full blown race engine with a much higher redline, than the stock LS 7000 RPM.
Old Oct 24, 2002 | 04:28 PM
Mase's Avatar
what i did, is actually secured the sensor to the throttle body.....then ran a hose to the pcv valve....
Old Oct 24, 2002 | 04:56 PM
Spinin4's Avatar
I've heard that the JG manifold is good for running alot of boost like something over 20 pounds. Anything below that and the skunk 2 is more than capable of doing the job. The JG also is most effective from 7,000 to 10,000 rpm.
Old Oct 24, 2002 | 05:12 PM
Vu's Avatar
Vu
Default Re: People running Skunk2 IM on Boosted B18B. Was it worth it...? (TsunamiCRX)
That's what I'm wandering about. Does the JG make a great deal of power on a boosted B18B under 7,000rpm?
Old Oct 24, 2002 | 05:25 PM
JV's Avatar
JV
Who?
Can't wait for the dyno comparison...
Reason i asked this question is because i recently picked one up for $150, which i thought was an excellent deal and had planned on making some cash from it...
I'm putting together a "turbo kit" as we speak and i could have used the $150 for other "more important" things. Just wanted to know if it was worth keeping. Looks like it is...
Old Oct 25, 2002 | 08:02 AM
DIRep972's Avatar
Smarter than you
i would definitly keep it.
i thought about waiting it out for the JG but I started to just think about the designs of the two manifolds and the skunk 2 seemed better for my application. plus i like that it looks stock when I pop my hood, although the JG is functional it looks like a friggen blimp.
sh!ft
Oct 15, 2010 01:38 PM
LightningTeg
May 8, 2009 05:46 AM
HondaIntegraR
Mar 9, 2005 07:00 PM
onesikcivic
Apr 26, 2004 07:15 PM
M.A.R.C.
Oct 20, 2003 01:16 PM
