90Dx intro question and future hopes
Old May 27, 2013 | 09:16 AM
Sgreg22's Avatar
Icon2 90Dx intro question and future hopes
Wats up every one so I bought a 90 dx hatch as a db (daily beater) its got. A bitof rust but for 175 k it runs like a champ except the spark plugs flood with oil I plan on changin the tubes n valve cover and doing a tune. Up which brings up a question the car sometimes stalls or loses all power when pulling away from a almost stop or stop it doesn't die but it won't move a few. Pumps of the pedal and it cruises away will this cure it ? Pretty much I want to ride it out till I can save cash for a b18 or b16 swap still haven't decided on what power level I want out of it thanks in advance ps while in park I noticed if I fully open throtttle it will sputter and back fire not sure if its tied to the problem mentioned
Old May 27, 2013 | 06:01 PM
BigD4207's Avatar
Default Re: 90Dx intro question and future hopes
Especially for a car with that many miles, get new timing belt, tripe check for correct timing, new fuel filter, and you will probably solve the sputtering issue for the most, as for oil in the spark tubes, the tubes have a seal, which I'm thinking you have to take the head off for, been awhile, but I flooded mine out due to a bad pcv valve, so might as well replace that as well to be sure. Cheap. But new headgasket is a must.
acidburn2k2
Aug 31, 2015 05:43 PM
carlosd68
12
Sep 28, 2012 08:07 PM
JesseCRX
Mar 8, 2010 04:32 PM
integg93
Dec 4, 2006 05:15 PM
B2FiNiTY
Jul 19, 2003 12:37 PM
