Problems with cable JDM b16 tranny and clutch disk.
I have a 91 Crx si that I'm swapping with a built N/A gsr Mated with a JDM cable B16 trans. Have everything that I need to put the engine and trans in the car but keep hitting a wall when it comes to the clutch disk and sliding onto the shaft, I have tried both big spline clutch disk and the normal sized spline clutch disk both of which did not work. Big spline was too big and normal spline seems too small, wouldn't even slide onto the shaft.
This is where I need the help on what to do! Getting tired of ordering clutch disks, it's making me want to just sell the car. This is my 4th Crx and I have done noumerous swaps in the past. This one part is just stumping me.
Any advice or suggestions will be appreciated.
Thanks in advance - Robert
Had a similar problem. Went though like 3 discs looking for the right one. Check the vin # on the tranny case. Different series use different discs i.e. J1, S1, Y1...
Well I finally got around to counting the splines on the tranny it has a count of 24 and so does the last clutch that I ordered ( the one that doesn't fit ) so what do I do from here?
It's roughly 1/16-1-8th too small. Called up LSD MotorSports and they are going to get me squared away. He thinks the first one they sent may have been the incorrect clutch and is going to send me another big spline. We talked on the phone for a while today had me take measurements and confirmed my input shaft is in fact the big spline measuring in at just a hair over a one inch Diameter. As far as a clutch alignment tool, I do have one but I always try to slide the clutch disk on the input to make sure before I button things up. Hoping the third time is a charm and I can get the engine done, in the mean time ill continue with my wire tuck.
Twisted Image
Transmission & Drivetrain
Apr 5, 2010 01:19 PM
mycivicislower
18
May 9, 2009 07:10 AM
turbo_ef9
Sep 6, 2004 05:12 AM
