what is this hose called guys? 93 del sol si
it exploded... disregard the duct tape- just a 5 min fix to get me home.
Part number? thanks. I bought some coolant hose at Canadian tire in two sizes. Just have to cut to fit.
That hose should be for your fitv on the bottom of your throttle body. Here is the water hose diagram for your car off of Majestic Honda with part numbers. http://www.hondaautomotiveparts.com/...++96+S%2CSI%29
Goodluck on your fix.
thanks, but does coolant come out of that hose? My car was overheating because of this hose breaking. So it is a water hose? Looked like engine to intake when I looked real quick.
Yes that's a water hose coolant does run through it, and the other hose right next to is your crank case breather hose which is a vacuum hose/port.
Joshka89- I THINK THAT is the one, but coolant or water runs through it on mine- the one that punctured. An AIR control hose does not sound like water/coolant runs through it???
majestic won't ship to canada. the hose is only a few bucks, need 2 of the clamps too- i can paypal someone the money plus 5 bucks for your trouble. plmk. im in windsor, ontario.
you don't need to buy that hose from Honda, a local parts store will have a house that'll work abs probably be cheaper
Curlybandit
Jul 22, 2018 06:42 AM
