F22A4 build suggestions.
I have an f22a4 engine with 200,xxx miles, and I want to gain a little hp here and there. What are somethings I can do to gain hp below $1k. Not a swap, just mods for my f22.
$1,000
no swaps
more power
200,000 miles
you could probably squeeze in a full rebuild, bump the compression up and add a mild cam and maybe still have enough cash to get it tuned.
IMHO, $1k is better spent on wheels, tires and suspension. if you already have that then save another $1,000-1,500 to go bigger on the rebuild. it's the same amount of work on your part (if you're doing the work) but with better parts and more payback.
no swaps
more power
200,000 miles
+1 for suspension.
-mill the head ~.040" to bump compression
-swap on an H23 intake manifold
-cam gear
-2.5" exhaust
-cheap header with modified 2.5" collector
-H23 manual trans
-socketed ECU and get it tuned.
I made 169whp with that setup on an F23 a few years back (almost 50whp over stock).
-cam gear
-2.5" exhaust
-H23 manual trans
