no start problem 97 honda civic non vtec
Old May 26, 2013 | 04:42 PM
greyEG's Avatar
Default no start problem 97 honda civic non vtec
Hello my friend has a 97 civic dx non vtec 1.6 motor. Today his car would not start. The starter cranks but does not turn over ( like no spark to get it going).
The hazard lights work, i hear the fuel pump.. so that means main relay is good right?
We tried to push start the car and we got some progress, the car turns on then quickly dies out, gets to about 600 to 800 rpm then dies out.
Could this be a distributor problem?
Also at one point the car did not turn on at all. That was bad ground and power connections for the battery.. we fixed that.. there was paint on the connections.
Thanks
Old May 26, 2013 | 05:13 PM
greyEG's Avatar
Default Re: no start problem 97 honda civic non vtec
bump
Old May 26, 2013 | 06:45 PM
gzes's Avatar
When my non vte didn't wanna start i changed main relay, fuel pump and turned out it was the ecu. Test ecu with a good ecu and see if it starts. If so then that's the problem
Old May 26, 2013 | 07:16 PM
greyEG's Avatar
bump
albert7
29
Feb 7, 2017 03:12 PM
honda4fun
Sep 22, 2009 06:14 PM
Sean EH2
Dec 4, 2008 08:04 PM
Hondaboy816
May 14, 2005 07:36 PM
FLCivic
Mar 27, 2005 07:37 PM
