a/c Idle problem
Old May 26, 2013 | 02:25 PM
susy76's Avatar
Default a/c Idle problem
I put new compressor, new drier,new seal and freon When I turn the air conditioner on, the idle is too low, If somebody know how I can fix this problem? Do I need put a A/C idle boost valve(1992 civic Lx )Thanks
Old May 26, 2013 | 02:38 PM
nealnanoHX's Avatar
Default Re: a/c Idle problem
My Civic has always done this and it is normal for the idle to drop a little with the AC on due to the extra load it puts on the engine. I have a Ls Vtec with D series AC. You could check to make sure your IACV is working properly as with will effect the idle with the AC since it controls the idle under all conditions.
Bhi Rds
May 8, 2016 06:19 PM
213374U
Aug 19, 2009 07:47 AM
joeramirez
Aug 15, 2005 02:29 PM
