Unlisted OEM part numbers for various Hondas
Seagull Management
Ever try to buy a part only to find out it's part of an expensive assembly and not available separately? Yeah, me too. Sometimes Honda doesn't list a part separately but it is available for a different or older Honda. Sometimes part numbers for a separate part are listed in technical service bulletins, but the parts lookup is never updated. In any case here are some of compiled, I will add more to this when I find more.
'97 - '01 CR-V rear lower control arm bushings (these probably fit Integra Type R and '92 - '95 Civic SiR as well, but I can't confirm) 52365-SH3-000
'88 - '00 Civic, '93 - '97 Del Sol, '94 - '01 Integra, '97 - '01 CR-V trailing arm bushings 52385-SR3-000
'01 - '05 Civic lower balljoints 51220-S5A-305
'96 - '00 Civic EX (D16Y8) vtec solenoid gasket between the two halves of the solenoid 36172-P08-015
'88 - '91 Civic SiR/Integra Xsi (OBD0 B16A) Vtec solenoid gaskets: Solenoid to head: 15825-PR3-005, Upper gasket: 36172-PR3-005
'97 - '01 CR-V JDM front bumer (the one with round holes for foglights) 71101-S10-G10
'92 - '00 Civic, '94 - '01 Integra, '97 - '01 CR-V and numerous other Hondas coil screws: 93892-0400608
