Wiring Harness easy fix??
Old May 25, 2013 | 10:30 PM
FloMotion's Avatar
Default Wiring Harness easy fix??
Hey so i have a DOHC ZC in my 91 Si and im wondering what i should do about a wiring harness??? I have the right harness for it, however the problem is that the harness looks all choppy and its throwing me codes...... Is it possible to buy a stock si harness and swap over all the pigtails?
Old May 25, 2013 | 11:32 PM
Bsixteen_CRX's Avatar
Default Re: Wiring Harness easy fix??
ZC harness and your si harness are identical. Just use your stock harness.
Old May 25, 2013 | 11:46 PM
slowDB7's Avatar
guess you didnt read that OP's stock harness looks all F*****d up and is throwing codes
your best bet is to try fixing your current harness and make it look good
and yes you can buy a stock si harness and swap pigtails if needed, sometimes they will pop up in the marketplace section or ebay
Old May 26, 2013 | 02:28 AM
swordofdoom's Avatar
DOHC ZC uses a complete different dizzy and cam sensor plug for OBD0. If your getting codes for the dizzy you need to swap the wires around. What are the codes you are getting. A lot of codes does not help.
Old May 26, 2013 | 02:51 AM
He said he had the right harness. He didn't mention if he reused his or used the one that probably came with the engine. Either way they are the same. Just have to re-pin 2 wires for the dizzy and cam sensor and that's it.
Here's a write-up from the FAQ section at the top of the ef page http://www.phatwhippincrx.20m.com/photo6.html
Old May 26, 2013 | 07:41 PM
FloMotion's Avatar
codes 6, 10, and 20. Being AIT Coolant temp and ELD. I have a new 89 Integ dizzy that i just put on! The car was running fine aside from the codes it showed and then we took off the harness, tried another one which didnt work cause of different pigtails and so we put the other one back on and now it turns on but doesnt want to crank or prime.... No its not the main relay i tried a few which are pretty much new. Good Soder joints and everything
ShadowKhaN
16
May 3, 2016 11:12 AM
mikeyindigo
Apr 6, 2016 09:16 PM
bbrian
Oct 22, 2005 11:18 PM
OutLuDeD
Aug 16, 2003 06:30 AM
