Quick question, 92-95 Civic & 94+ Integra....mech or electronic speed sensor?
Do 92-95 Civics and 94+ Integras use mechanical or electronic speed sensors on B-series engines?
I've been reading up on removing the power steering, but a major concern of mine is that the vehicle speed sensor (VSS) in my 92 Integra is mechanical and looks like it gets its lubrication from the power steering system. I read a write-up for a Type-R removal, but they mention no concerns about retaining speed sensor lubrication.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
yes. all 92+ civics and 94+ Integra's use an electrical VSS.
In JDM land, some EF (SiR) & DA (XSi/RSi) use an electronic VSS also.
Looks like I have my work cut out for me since the 90-93 Integra's use a hydraulic pump to regulate steering fluid pressure, which is also what it uses for a speed sensor. If the vehicle speed sensor seized up....ach! Quote from Helm's: "It [the vehicle speed sensor] is driven by the speedometer gear shaft which in turn is driven by a helical gear on the differential."
92-95 Civics and 94+ Integra owners didn't have to worry about this stipulation when doing a power rack to manual-power rack conversion by removing the pump and resevoir. Looks like I'm gonna have to get creative. Thanks for the info Katman.
[Modified by mojoGSR92, 9:31 PM 10/23/2002]
mojoGSR92
Oct 25, 2002 01:16 PM
92, 9295, 95, acura, civic, clean, conversion, electronic, fit, integra, lubrication, mechanical, seized, sensor, speed, vss
