need help with brake problem
Old May 25, 2013 | 12:21 AM
kazaa187's Avatar
Default need help with brake problem
Ok i got a 92 civic i piced up it had a ls in it and brakes werent the greatest an i just put a b2 vtec it which had a skunk2 manifold on it now pedal goes straight to floor to stop and when car is off you hit the brakes you can hear air getting sucked in from intake.i just cant figure it out
Old May 25, 2013 | 12:57 AM
street93eg's Avatar
Default Re: need help with brake problem
Did you start with the basics? Air in the brake lines, damaged vacuum lines or a bad master brake cylinder?
If it was squishy before the swapped part it might not be the intake mani
Old May 25, 2013 | 01:22 AM
kazaa187's Avatar
Yes i blead brakes like 5 times fluid is clean no leaks anywhere if i crimp the booster vacuum line so it doesnt get as much vacuum brake pedal is hard as rock an the pedal doesnt sink to floor as i hold it so thats why i dint think it was master
Old May 25, 2013 | 01:23 AM
kazaa187's Avatar
I didnt replace booster but is there a way to test it
Old May 25, 2013 | 01:59 AM
street93eg's Avatar
If the O rings in the master cylinder are worn out it can cause soft pedal feel. Bad booster would make it hard to press the pedal.
Old May 25, 2013 | 02:17 AM
kazaa187's Avatar
Alright ill check that out today
Old May 25, 2013 | 03:16 AM
jbpnoman's Avatar
Do you have the brake booster vacuum line hooked up correctly? Is there a check valve in it?
Old May 26, 2013 | 01:47 PM
kazaa187's Avatar
Ya so i changed the master and bench blead it an still no brakes it does have a check valve an i got it right to the back of im the only one that size
Old May 26, 2013 | 01:51 PM
kazaa187's Avatar
Im thinking it has something to do with vacuum tho because car of an you pump brakes you can hear it pull air through the intake and also people before me removed the canister for vacuum lines i dont no if that would cause a problem or not
91integra_rubio
Apr 20, 2009 03:01 PM
ZippyZivic
Mar 24, 2009 07:58 PM
jikespingleton
Jan 2, 2007 01:31 AM
Del_Sol_s
27
Mar 4, 2006 06:49 AM
MrEg
Sep 22, 2003 04:49 PM
