screwed up obd1 mpfi conversion
Old May 24, 2013 | 07:23 AM
Zack Gunther's Avatar
Default screwed up obd1 mpfi conversion
got a 91 civic hatch dx. just finished putting everything back together after doing the conversion. im getting a crank no start condition. iv got spark and fuel but it wont start. iv double checked all my wirring for the dizzy and ecu and it is all correct and im not sure were to go from here... any ideas?
also, before i did the swap my car was dieng at random times the idle would be very speratic woul fluctuate up and down or just be very high. somebody said it could be a tps... idk. but it eventually died and wouldnt start back up.
somebody please help... thanks!
Old May 24, 2013 | 07:50 AM
4drEF's Avatar
Keyboard Humorist
Default Re: screwed up obd1 mpfi conversion
ECU throwing any codes?
Try switching the two white wires on the distributor?
Old May 24, 2013 | 08:05 AM
its not throwing codes... checked the white wires pretty sure there right swithced anyways same thing...wont start. i keep seeing people saying switch the tps wires but not sure which ones to switch?
Old May 24, 2013 | 09:34 AM
ED3 SEDAN-GSR's Avatar
The two outside wires on the tps plug. Leave the middle one where its at. But that shouldnt keep it from starting. Have the icm and coil checked. When i did my gsr swap both the icm and coil were bad and it wouldnt start. As soon as i replaced them it fired right up
Old May 24, 2013 | 02:12 PM
well i just found my compression tester... it read a big fat 0 on 1 2 and 3... didnt even bother with 4!
Old May 25, 2013 | 12:44 AM
swordofdoom's Avatar
Fried piston rings. A buddy of mine had this problem. It would crank over and over but never start. He took the motor apart and viola. Rings were shot worst than ****.
Old May 25, 2013 | 04:58 AM
Creator's Avatar
Zero in three of the cylinders? No one else found that odd? I've wasted a few motors in my time, but I've never seen zero across the board.
Old May 25, 2013 | 07:11 AM
just took the head off and im pretty sure the exhaust valves on all the cylinders are burned up... they look pretty well screwed. can bad valves cause 0 compresion?
Old May 25, 2013 | 08:38 AM
90_EX_Civic's Avatar
yes
Old May 25, 2013 | 08:56 AM
yea thts what i thought... what would cause burned valves on all cylinders?
Old May 25, 2013 | 06:32 PM
HEADS OR TAILS's Avatar
misfire, detonation etc..
Old May 28, 2013 | 07:35 AM
4drEF's Avatar
Keyboard Humorist
FYI:
The TPS wires won't create a no-start situation.
The Two white wires do create a no-start.
You should have put a cap full of oil in each cylinder after finding the zero compression especially if the motor had been sitting for a long period of time.
98gsr-808-91dx
Nov 17, 2009 04:36 PM
HONDAlover369
Sep 19, 2008 12:47 PM
93NTEGLS
13
Mar 4, 2007 03:05 PM
100whplusperliter
Jun 7, 2005 01:58 PM
PrecisionPerformanceParts
Apr 13, 2005 09:33 AM
