k20 da running help
me and my brother have been building his da for the past few years here and there.the plan was to build and boost the car but he stopped working on it due to having a kid due any day now and as a surprise i am trying to get it running perfect for him just na for now
the problem-
the car will only idle with the trottle cracked slightly,when i go to rev it up it delays then revs up. if i give it constant throttle for example i hold it at 2k rpms it pops and seems to bogg and backfire. i am pretty sure its running to rich seeing as how i saw a flame shoot out the header,but im not quite sure y unless its my fuel pump being to large.i know the fuel pump says operating psi is 72.5 but i figured the regulator would be able to control it but i may be wrong. i tired running a stock map sensor but didnt change,ive messed with fuel pressure going from 40 all the way to 60 any input would be greatly appreciated. this is my first k swap car ive done if anyone could tell me how to upload a video i took a qick video of the car running.
mods- k swap header,
skunk 2 throttle body
iac delete
kpro
bosh o44 external fuel pump
fcs tank
cant remember what map sensor but its red 4 bar-not hondata
aeromotive fpr
-8 fuel lines
the problem-
iac delete
kpro
fcs tank
aeromotive fpr
-8 fuel lines
Import_2
Oct 23, 2008 08:35 PM
