98 Civic Battery Light On - Battery and Alternator good
Old May 23, 2013 | 03:13 PM
CivicInUse22's Avatar
Default 98 Civic Battery Light On - Battery and Alternator good
My car has had the battery light on for awhile now. It is very dim but it is on. I tested the Battery and it checks out good and also tested the alternator and it is good. Where do I go from here?
Also High beams aren't working and I hadn't found any posts where people have had both high beams not working issue. Where do I look for the problem there? Might be a ground idk.
Old May 23, 2013 | 05:12 PM
Default Re: 98 Civic Battery Light On - Battery and Alternator good
anybodyy?
Old May 23, 2013 | 05:30 PM
murphy95si's Avatar
all I can think of is check fuses and for high beam issue could be a switch maybe someone with more exp can chime in
Posted from Honda-tech.com App for Android
meelow
Apr 29, 2010 09:35 PM
Nocturnal
May 13, 2009 07:58 PM
MDAnhorn
Dec 28, 2007 04:15 AM
ekim952522000
Jan 6, 2006 06:25 PM
idriveadelsol7
Dec 11, 2005 04:05 AM
