Skunk2 Ultra Race yields 80+ mid range hp
Old May 22, 2013 | 02:40 PM
Spawne32's Avatar
Default Skunk2 Ultra Race yields 80+ mid range hp
http://cms.skunk2.com/id/933/Skunk2-...itive-results/
There's nothing better than installing new parts and seeing instant gains on the dyno. Luis is ecstatic with his new setup... He recently made a pass of 10.40 @ 153 MPH, and barely ran this setup this month.
Take a look at the dyno with an impressive gain of over 80+ WHP in the Mid-Range!
Current Setup:
32PSI on the Ultra Manifold compared to 36PSI on the Edelbrock Manifold
9.0 Compression Ratio
Max RPM of 9400 rpm
Pump Gas E85
Skunk2 Pro1 Camshafts
Skunk2 Pro Series Cam Gears
Skunk2 Ultra Race Manifold
Skunk2 90mm Throttle Body
Old May 22, 2013 | 03:01 PM
gringotegra's Avatar
Default Re: Skunk2 Ultra Race yields 80+ mid range hp
Kind of deceiving of a dyno sheet since it looks like it is spinning in the RED dyno sheet. Would like to see the Tq numbers since they will tell the truth....
The 7000rpm-9000rpm is just too straight/flat
Old May 22, 2013 | 03:34 PM
Gunmetal_B20_Hatch's Avatar
Not trying to start a flame war, but it looks like VTEC crossover was moved.
Old May 22, 2013 | 05:24 PM
slayer423's Avatar
plus some better tuning or different afr's im sure. but 80 is a lot so i am sure it does gain a bit
Old May 22, 2013 | 06:16 PM
DDTECH's Avatar
Can nobody just say wow, GJ? .. Seriously.. there's a lot of variables, obviously. But all everyone cries on this forum is "I WANT DYNO SHEETS, I WANNA SEE WHAT IT DOES ON THE DYNO!!!!" When that's provided people always pick at it..
Then you produce track results, and then there's more picking.. the air wasn't cold enough, the guy had to **** before he made a pass.. retarded..
Now and days, no other companies can just compliment each other and its sickening.
Well from one guy to another, Dave, Skunk2, Good job.
Old May 22, 2013 | 07:22 PM
th3pwn3r's Avatar
It's red, it's junk, I hate the color red. Seems impressive thus far.
Old May 22, 2013 | 07:32 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
great numbers! i would get it if i had the money. i wonder if that manifold is better suited for higher hp cars or for the day to day driver
Old May 22, 2013 | 07:38 PM
doood's Avatar
been there done that
then posts like this can be construed as nut riding
i have nothing else to share. just adding fuel to the impending fire.
Old May 22, 2013 | 07:43 PM
Spawne32's Avatar
dont shoot the messenger
Old May 22, 2013 | 08:12 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Yeah so what, but we all know what it is all really about - PEAK HORSEPOWER!!! Who cares it had some gains midrange on a almost 700 whp car, it lost some of it's most important number!!!
Burn baby burn...
Old May 22, 2013 | 08:28 PM
Dark_Teg's Avatar
Very nice, one of these days when I do an all out build I'll keep this in mind.
Old May 22, 2013 | 08:45 PM
lsvtecracer's Avatar
I tune the car and just move the vtec point a few hundred rpm just to test something out. By picking up 80 hp in the midrange, the car went from 144mph in the quarter to 153 mph in the quarter. I can post a torque curve if anyone want to see it. Also, we are also running 4 less lbs of boost with the skunk 2 ultra. Injectors are at about 88 % duty cycle so that's why I stop at 32 psi instead of tuning it to 36. This particular motor has been together for about 6-7 years now and has hundred of dyno passes on it. Overall, i'm very impress with the skunk 2 ultra manifold.
Steve
Old May 22, 2013 | 08:53 PM
Spawne32's Avatar
Wish you guys could have tested this with an ultra street lol
Old May 22, 2013 | 08:56 PM
I'll be testing this manifold out on my race car soon that has an a2w setup. I'm taking off my hp racing sheetmetal manifold and will be using the 5.5 liters skunk2 ultra manifold in its place.
Steve
Old May 23, 2013 | 04:01 AM
DDTECH's Avatar
Depending on gearing, midrange will always play a role going down the track - its amazing the amount this is overlooked.
Old May 23, 2013 | 04:14 AM
MR.johnson's Avatar
that seems to be the case around here and its sad.
Old May 23, 2013 | 07:40 AM
DDTECH's Avatar
Personally, I think dyno numbers mean jack ****. Put it on the track and lets see what it does.
Old May 23, 2013 | 07:47 AM
I am just pointing out the obvious on a dynosheet that is all..
Old May 23, 2013 | 07:55 AM
My tuner said the same thing to me the same exact thing
I've been thinking of switching my blox IM for a elderbock to improve my mid- top end, but this skunk2 street manifold might be for me. The ultra seems a but much for my motor
Old May 23, 2013 | 08:22 AM
Spawne32's Avatar
Originally Posted by justYncredible
My tuner to me the same exact thing
Results arent back yet on the ultra street, the race version has proven itself a worthy competitor though for turbo setups.
Old May 23, 2013 | 08:39 AM
sanman000719's Avatar
until this become popular or the big named guys are pushing the **** out of it well you will have people hating it lol thats just the way it is.
Old May 23, 2013 | 08:40 AM
isn't speedfactory already running this manifold
Old May 23, 2013 | 08:55 AM
seelback's Avatar
yes, and so far they seem to like it. its in the blue ek coupe, not sure about the eg hatch.
Old May 23, 2013 | 09:00 AM
seelback's Avatar
+1, its crazy how everyone is just hyped up about peak whp numbers. its amazing how different a car is when you've changed something(tuning involved) and picked up midrange hp and tq and how it effects your 1/4 mile time and mph. im big into track testing after ive changed something and getting tuned.
Old May 23, 2013 | 11:11 AM
tepid1's Avatar
Looks like the test mule has a S372 on it.... Steve, can you confirm that?
And if it is.... at 36psi that thing should be well into the 900's.
