Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
___***1320Fuel.com*** Blackworks Coilover/Loweing Spring Sets***___
Old May 22, 2013 | 12:52 PM
1320fuel.com's Avatar
Default ___***1320Fuel.com*** Blackworks Coilover/Loweing Spring Sets***___
Pm Us for ordering/pricing or visit our website at http://www.1320fuel.com
Blackworks Coilovers Sale!!
The New BWR SS Coilover feature's a wide range of height adjustments without changing the spring compression and sacrificing the shock stroke. Traditional Coilovers requires the movement of the spring perch to determine the ride height, causing a reduction in suspension travel and induce coil spring binding. The bottom shock fork / connector is threaded to allow height adjustments to each drivers need without having to shorten the suspension travel by maintaining the original spring perch location. With this function, each driver can lower the center of gravity to achieve better handling, without sacrificing ride quality
LOWERING SPRINGS
Blackworks Racing is proud to announce the new addition to our suspension line. Our Progressive lowering springs are CNC-wound and made from high quality SAE 9254 Spring Steel. After our rigorous quality control stages our springs are shot-peen stress relieved, and then sent to powder coating then heat treated. Our lowering springs help improve increased stability through hard cornering, while giving your car a ultimate clean look
Old May 22, 2013 | 05:28 PM
Default Re: ___***1320Fuel.com*** Blackworks Coilover/Loweing Spring Sets***___
ttt
Old May 23, 2013 | 11:21 AM
ttt
Old May 29, 2013 | 12:02 PM
bump
Old May 31, 2013 | 12:44 PM
all PM's Replied.
Old Jun 5, 2013 | 12:48 PM
bump
Old Jan 21, 2014 | 03:04 PM
ttt
RedlineMotive
Jun 18, 2012 09:23 AM
carvers
Suspension & Brakes
Apr 20, 2009 05:21 PM
m1northreat
Suspension & Brakes
May 5, 2007 01:01 PM
Jazz
Suspension & Brakes
Feb 10, 2005 07:38 AM
