B,D series random parts,RHD type R engine harness,.48ex turbo,lots of items,Pics!!!!
All prices are firm and picked up,I am not looking for trades unless you have some inner door handles from a EG,Rear disk setup,40-40 prop valve,carbon fiber EG hatch duckbill,or a I.T.R rear swaybar.
Located in Trinity-New Port Richey,34653
OBD-0 LS intake manifold. $40
D-series fuel rails. $15 each
B-series Vtec spark plug wires,came off a 99 jdm type r swap. $25
D-series vtec obd1 cam gear,came off a jdm d15b vtec. $15
Water pumps $15 each.
B-series Vtec 22t
LS 19t
D-series Vtec P08
Factory battery grounds,power Leads for the starter & fusebox,chassis ground,$5 each
EG-DC auto to manual conversion lines. $25
EG clutch master cylinder. $25
Clutch slave cylinder X2. $25
Clutch Fluid reservoir & line. $5
LS driver side torque mount bracket with AC tensioner. $40
LS P54 PS pump bracket. $30
T3 .48 ex housing Garrett turbo,good for a SOHC that wants super quick spooling,internally gated,feels good,just is dirty as hell because it came from a turbo diesel Mercedes i believe. $100
GSR throttle cable and bracket $25
O.E.M fuel feed lines $5 each
EG-DC B-series intermediate shaft. $75
B-series flywheel. $50
99 JDM RHD I.T.R engine harness,uncut,mint,fresh and clean. $125
Call or text 727-859-3216
B-series Vtec 22t
LS 19t
D-series Vtec P08
ApexiChild
Mar 16, 2012 06:57 PM
