DPFI to MPFI OBDO to OBD1 conversion question
Old May 21, 2013 | 09:10 AM
historic4thewin's Avatar
Default DPFI to MPFI OBDO to OBD1 conversion question
Hey guys i have a bone stock 91 ef hatch DX. Its got a obdo d15b2 dual point fuel injection in it. I just recently bought a obd1 lsv. I know that i need to convert it from dpfi to mpfi and obdo to obd1. I ordered a obdo to obd1 conversion harness for the ecu and dizzy. Can anyone send me a link or tell me exactly how to convert it from dpfi to mpfi if i am converting to obd1?? also how to wire for vtec?? please help asap. Would like swap in asap so i can take her to hyperfest mid next month! Also would b series axles and shift linkage fit? they came with the swap and were on a eg hatch before.
Thanks guys
Old May 21, 2013 | 09:28 AM
4drEF's Avatar
Keyboard Humorist
Default Re: DPFI to MPFI OBDO to OBD1 conversion question
Shift linkage, probably not.
Axles, yes.
Old May 21, 2013 | 09:31 AM
Appreciate the response! So the dpfi to mpfi conversion is the same obdo and obd1? wires will be the same?
Old May 21, 2013 | 09:34 AM
4drEF's Avatar
Keyboard Humorist
OBD1 jumper adds a few wires for vtec, heated O2, etc, but it's main function is to route the OBD0 wire to the correct pin on the OBD1 ECU.
What you are doing is converting the OBD0 wiring from DPFI to MPFI.
When you are done with that, all the wires will exist and be in the right place for you to plug in the OBD1 jumper harness and all the wires will be going to the right place.
Don't forget the TPS wiring!!!
Old May 30, 2019 | 04:10 PM
Lil ak89's Avatar
Thanks guys
Hey man i habe the same engine block. Idk how to do the mini swap.
dr_latino999
236
Mar 28, 2020 12:34 AM
VTEC_Honda
Jun 1, 2011 03:54 PM
2_Envy
Mar 20, 2010 04:46 PM
projsectEF
Jul 25, 2006 12:32 AM
Ls On StErIoDs
Sep 12, 2005 09:04 PM
