No crank sensor on JDM J30a (bypass trick?)
I'm in the process of swapping out an engine in a 2002 accord V6. There is no CKF sensor on the JDM engine but there is one the USDM engine (which I knew was going to happen) I've done the CKF bypass trick on civics before with good results, but didn't know if there was a way to pull this trick off on the accords? Or would it be easier to switch over the oil pump and crank sensor from the USDM since i have the engines out? Any input would be great. Im sure people have run into this issue when swapping in accords.
I also have the JDM ECU, but I don't know if that will work
thirsk66
Mar 20, 2014 10:01 AM
Unphzd
Nov 23, 2010 01:47 PM
