Civic won't start PLZ Help
Old May 20, 2013 | 10:44 PM
d_boi_swag's Avatar
Default Civic won't start PLZ Help
Ok I'm trying to get my hatch going. I swapped in a b18a1 that was running in my integra. I have fuel and I have spark and I would assume the compression is good because it ran great before the swap. I have no dash lights tho which makes me suspect of the ignition switch but I had a mini me in before that didn't have a problem and I'm also using the same harness. I relocated the battery to the trunk and had it ground from the neg battery post to the trunk then I thought that might be the issues so I ran the cable to the bay and grounded to transmission then to the body and now it won't even crank I'm stumped and need help thank you
Old May 20, 2013 | 11:15 PM
88LsRex's Avatar
Default Re: Civic won't start PLZ Help
if you have spark, and you have fuel, you have a timing ussue
Old May 21, 2013 | 05:48 AM
d_boi_swag's Avatar
I don't think that's it it ran before fine and the no dash lights
Old May 21, 2013 | 08:57 AM
d_boi_swag's Avatar
Bump
Old May 21, 2013 | 05:14 PM
d_boi_swag's Avatar
Fixed had the blue plug and white plug switched around on the fuse box under the dash
iheartjayDem
11
Jul 24, 2009 09:28 AM
JDM Lyfestyle
14
Jun 29, 2009 06:35 PM
SweetDA9_TR
Mar 30, 2009 01:37 PM
p_en03
Jan 24, 2008 05:10 PM
JToolz
Feb 14, 2004 11:49 AM
