Transmission & Drivetrain Gearboxes, Differentials, Clutches
HELPP s4c/y21 final gear
Old May 18, 2013 | 02:20 PM
tarzzan's Avatar
Default HELPP s4c/y21 final gear
Hello!
I wanted to know if a final gear ratio(not oem obv) of a s4c gear box fits on a y21.
Best regards!
Old May 19, 2013 | 07:54 AM
David @ Synchrotech's Avatar
Default Re: HELPP s4c/y21 final gear
USDM S4C and Y21 both use the same 4.40 (66X15) FD set.
Here is a link that will help: https://honda-tech.com/forums/transmission-drivetrain-127/tech-tip-b-series-final-drive-identification-3095354/
Old May 19, 2013 | 10:27 AM
tarzzan's Avatar
So i can put in a y21 an aftermarket final gear for s4c not??
thank you so much
Old May 19, 2013 | 05:33 PM
Yes you can use the same aftermarket FD in either one.
sslude
Jan 3, 2003 07:25 PM
HatchSteer
Nov 22, 2002 06:04 AM
Dorikamu
Jun 20, 2002 11:39 AM
