Buddy Club Coilover install
How should I secure the front break lines? My Buddy Club N1 Spec coilovers don't have the same mounting brackets for the factory front lines. Whats the solution? Zip ties??? (I hope not)
Thanks in advance.
Thanks in advance.
Well when i had my pic coilovers on my hatc they did not have mounting spot for my braided lines so i just zip tied with slack on each end of connections
They are lines that you zip tie your shocks.
brake lines on the other hand, are lines that you secure correctly with a bracket.
Seriously though, it you decide to use zip ties.. check the lines often to make sure they are secure and not rubbing. Not respecting your brake system is suicide.
