Brake Lines after installing a Coilover
Old Oct 15, 2001 | 06:30 PM
RineRacing's Avatar
Default Brake Lines after installing a Coilover
After installing my coilovers I noticed that the brake line brackets no longer had a place to attach to the shock so I took the brake line brackets off and zip tied the lines to the damper fork. This looked to be the only place to zip tie brake lines. What have the rest of you guys done to get around this problem?
Side note: I used the rubber bushing from the bracket so that the zip tie wouldn't be in direct contact with the brake line.
[Modified by Geratol, 7:31 PM 10/15/2001]
TSutton
Honda CR-V & Element
Jan 4, 2018 07:09 AM
SOHCNightmare
Suspension & Brakes
May 18, 2009 07:22 PM
