Ball bearing compressor/jounral turbine bearing
Compressor side has bb and turbine is journal bearing.. currently using standard journal bearing oil restrictor . Smokes after a hard hit and as oil pressure rises. Little bit of oil in compressor housing none in turbine... Should I be using a ball bearing oil restrictor? Confused as most turbos are dual ball bearings or journal. Thanks
Hellahflush
Mar 27, 2015 05:15 PM
craftech
10
Oct 1, 2008 03:48 PM
