5 lug conversion on a 88 CRX....
Old Oct 23, 2002 | 12:42 PM
EG-CoolGuy's Avatar
Default 5 lug conversion on a 88 CRX....
is it possible?
i've heard that you can swap out the sus. and replace with '92-'95 EG so in essance wouldn't it be possible to replace with ITR sus?
thanx for the help.
-ben
Old Oct 23, 2002 | 12:50 PM
4drEF's Avatar
Keyboard Humorist
Default Re: 5 lug conversion on a 88 CRX.... (EG-CoolGuy)
Yes. Well, for atleast the reasrs I know it's possible. I have no idea what you would do for the fronts though.
Old Oct 23, 2002 | 12:58 PM
ghettocrxsi's Avatar
Default Re: 5 lug conversion on a 88 CRX.... (4drEF)
I have 92-95 eg front suspention..all you need to do is use your 88-91 upper mount.. the u joint with the mounts... you just pop the joint and put it on the 92-95 stuff... also... the rear type r suspention is the same as the civic... so u just bolt it on but you have to use teh civic mounts... you only use the integra control arms and brakes... and the civic lower control arm... the integra ones are longer and will mess up your alingment..
Old Oct 23, 2002 | 09:36 PM
EG-CoolGuy's Avatar
Default Re: 5 lug conversion on a 88 CRX.... (ghettocrxsi)
thanks for the info guys!!
Old Oct 23, 2002 | 10:19 PM
xtrafastcivic's Avatar
uhh his name is ghetto...
that is not the right way to do it....
http://www.jarofbees.com/tech/da_5lug/
Old Oct 24, 2002 | 10:28 PM
Default Re: 5 lug conversion on a 88 CRX.... (XtraFastCRX)
I never said it was the right way to do it... but it works...
j me4door
Feb 3, 2009 11:48 PM
ej2civic
Dec 2, 2007 09:55 PM
spatula
Dec 20, 2005 07:30 AM
Nerv2g
Sep 22, 2003 09:50 PM
