d16z6 Torque sequence for removing main cap, follow # reverse order????
Old May 16, 2013 | 07:51 PM
EG-SIXV-TEC's Avatar
Post d16z6 Torque sequence for removing main cap, follow # reverse order????
Hi i have a d16z6 engine ready to be removed. i need to remove the main gridle cap on the engine to remove the crank later etc/..
i have the haynes book but, what torque sequence when removing the main cap do i use? do i use number 1,2,3 and so on??? or start from 10 to 1 etc? backwards when removing
and is resembling same as the torque sequence 1,2,3 so on?
Old May 16, 2013 | 08:44 PM
Gemar's Avatar
Default Re: d16z6 Torque sequence for removing main cap, follow # reverse order????
When removing always start from outside bolts in. Like two on left side then the two on right side. Working your way in the middle. And yes to that last part.
lilhatch89
Jul 27, 2014 04:59 PM
swirve1
Feb 4, 2010 08:43 PM
LaOstha
11
Sep 16, 2006 10:45 AM
xXx Justin xXx
10
May 14, 2003 06:44 PM
