d16z6 Torque sequence for removing main cap, follow # reverse order????
Hi i have a d16z6 engine ready to be removed. i need to remove the main gridle cap on the engine to remove the crank later etc/..
i have the haynes book but, what torque sequence when removing the main cap do i use? do i use number 1,2,3 and so on??? or start from 10 to 1 etc? backwards when removing
and is resembling same as the torque sequence 1,2,3 so on?
Re: d16z6 Torque sequence for removing main cap, follow # reverse order????
When removing always start from outside bolts in. Like two on left side then the two on right side. Working your way in the middle. And yes to that last part.
LaOstha
11
09-16-2006 10:45 AM
