No VTEC and Cyl. 4 Misfire
Old May 15, 2013 | 08:54 PM
PaulMc's Avatar
Painfully Stupid
Default No VTEC and Cyl. 4 Misfire
Just installed an oem rebuilt motor. Motor runs like it should but it has no vtec and a misfire in cylinder 4. Could these two be related? Any info would be appreciated. I searched and only find the common problems; spark, air/fuel, compression, ect. which are all okay. Any info will be appreciated as I am very anxious to drive this car after two years.
Old May 16, 2013 | 06:26 AM
itr#1334's Avatar
Default Re: No VTEC and Cyl. 4 Misfire
CEL?
Old May 16, 2013 | 08:04 AM
PaulMc's Avatar
Painfully Stupid
CEL is for the misfire and an oxygen sensor, possibly both sensors.
Perhaps VTEC will not engage unless all four cylinders are firing properly?
Old May 16, 2013 | 11:47 AM
Aesthetic Gains's Avatar
Dos Pupusas
VTEC won't engage due to the CEL.
Have you tried a crank sensor or maybe another distributor?
Is it a BAD misfire? As in, #4 cylinder not firing at all? Or just a random misfire?
I'll help you as much as I can. Text/call me, you have my number.
Old May 16, 2013 | 01:45 PM
PaulMc's Avatar
Painfully Stupid
Because of which cel won't it engage? The misfire or the o2 sensor? Haven't tried a crank sensor or another dizzy yet, and the misfire isn't TOO bad.
I'll PM you.
boostedjdmda
12
Aug 16, 2009 06:41 PM
Nathan_volcom
Jul 17, 2008 01:26 PM
tc_gts
Jul 3, 2008 06:47 AM
vietblood87
Jul 14, 2007 09:58 PM
HUYNH
Aug 2, 2006 01:00 AM
