92 civic hatch Car creeps to H then drops down then Back to normal
Old May 15, 2013 | 06:10 PM
pigskinrodeo's Avatar
Icon2 92 civic hatch Car creeps to H then drops down then Back to normal
So tonight were driving and i realize that the Coolant temp gauge was starting to slowly start creeping towards the H then before i could get the car stopped it level backt o normal. It happen sometimes on Acceleration and other just when ever.
Now 2 years ago I Replaced the Hd Gasket along with the thermostat. Just 2 months ago i replace the radiator cause it was the original radiator of the car and it was corroding on the out side around the the whole metal sides. I bleed the system and all then we took a drive to WV last week to visit friends and had no problems. So i'm concered if this is a Coolant temp problem or a acutal in car gauge.
In the winter i noticed that the guage sometimes seem like it was stuck on the Cold side after 20 mins driving till you smack the top of the interior over the gauge and once you do that it came moved to the normal position. Don't know what to do ? Any help would be great
Old May 15, 2013 | 06:40 PM
fonkernuckle's Avatar
Default Re: 92 civic hatch Car creeps to H then drops down then Back to normal
Sounds like the gauge to me since you say you smack it and it changes:I would replace it or borrow one to confirm it being bad or install an aftermarket temp gauge with sensor and see if it happens with it too.
Old May 15, 2013 | 07:04 PM
B_Swapped93's Avatar
sounds like the gauge. try a different cluster with a known good temp gauge not something you want to have not working right.
Old May 15, 2013 | 07:32 PM
So i took it back out a hour later and try seeing if it would do it again well it didn't peg at the top in the H but id stay about a quarter size under the H and when i got home the FAN WAS RUNNING constantly while at idle.
Old May 15, 2013 | 07:43 PM
jbpnoman's Avatar
Is your thermostat a Honda unit, or an aftermarket/non-OEM replacement?
Old May 15, 2013 | 09:01 PM
Honda Oem
Old May 15, 2013 | 09:47 PM
peteyparado's Avatar
sound like thermostat? could be defect?
or try bleeding the system again
Old May 15, 2013 | 10:19 PM
okay just went out and checked car after it cooled down. No coolant in the radiator now mind you though the the coolant overflow tank is completely full. ?
I had a head gasket leak 2 years ago. Now when i had that my coolant reservoir was empty wtf ?
Guess i should do a pressure test.
Fosterryan
Jan 6, 2015 09:01 PM
escowop
25
Sep 6, 2010 05:29 PM
92civiclxny
Jul 22, 2010 05:14 AM
Paulie10
Jun 13, 2009 03:17 PM
mattmw88
Oct 19, 2004 09:36 AM
