Rear Window Tint - second layer stuck
Old May 15, 2013 | 11:25 AM
mail4hemanthr's Avatar
Default Rear Window Tint - second layer stuck
Hi,
I have honda 2002 accord and tried to remove the rear window tint. First layer came off very quick when i had soaked the window with soap solution and garbage bag. But, the second layer is being a pain. Tried ammonia, steamer, heat gun et....
I bought below item from menards as per the forum's suggestion. This doesnt help either... any suggestions?
http://www.menards.com/main/paint/cleaners-thinners-removers/paint-stain-removers/solvent-based/rust-oleum-aircraft-remover/p-1963198-c-8159.htm
Old May 19, 2013 | 06:33 AM
danyn's Avatar
Default Re: Rear Window Tint - second layer stuck
Originally Posted by mail4hemanthr
Hi,
I had the same situation on 97 Civic, window tint was baked in the desert for 16 years. The rear window tint especially difficult because sun dried and stuck to the defroster lines ... 5 words: "steam, steam, and more steam." Eventually, if you steam the window tint long enough that last layer will loosen and peel off. A long neck scraper from Harbor Freight also helped. good luck...such a pain
Old May 25, 2013 | 07:37 AM
sleepyaccord96's Avatar
go to wal mart and buy a clothing steamer. steam your windows until is super moist and hot and the tint will peel right off. no sticky residue left over
Old May 29, 2013 | 05:44 PM
zArlen's Avatar
Heat gun from harbor freight... heat it up enough and it should loosen the adhesive and peel off. It'll leave glue behind so follow that with a good foaming glass cleaner and scrape as much as you can off with a razor blade. You'll probably go through a few blades. If you're lucky, a heat gun, glass cleaner and blades is all you will need. I have done two cars this way with great results. But if there is still glue left over, a good liquid adhesive remover and rag should get the rest off.
Old May 31, 2013 | 03:57 PM
ej1 rep's Avatar
Omg dude, please do not use a razor blade on the rear window to get tint off, I did that on my first civic and ended up scraping the defroster lines with it.
Old May 31, 2013 | 04:13 PM
zArlen's Avatar
Ok, well.... I should reword things. Use the razor blade and glass cleaner to scrape the adhesive off but be smart enough to only scrape the glass.
9hatch6
May 20, 2006 01:20 PM
Scotty B
Honda S2000
37
Nov 28, 2005 10:57 AM
stangman39
Oct 2, 2005 12:19 PM
