Type R cluster in LS causing high idle
Old May 15, 2013 | 05:25 AM
dc2_jon's Avatar
Default Type R cluster in LS causing high idle
I just bought a ITR cluster for my 98 LS when I plugged it up my rpm jumped from idling at about 1k to between 3k and 4k and when I turn my lights on it drops to zero and my temp gauge spikes. I've tried searching and I couldn't find an answer. Hopefully some one knows what this **** is
Old May 15, 2013 | 11:45 AM
B_Swapped93's Avatar
Default Re: Type R cluster in LS causing high idle
you know that cluster is NOT a direct fit....put the old one back and see what happens
Old May 15, 2013 | 01:07 PM
dc2_jon's Avatar
yes I know its not a plug and play. I followed
https://honda-tech.com/forums/acura-integra-6/%5Bfaq%5D-how-install-integra-type-r-cluster-into-your-non-itr-integra-gsr-ls-etc-1836281/
And when I plugged it in that's what happened.
Old May 15, 2013 | 03:16 PM
but have you tried with the old cluster again since ?
tjlewis10
Sep 11, 2017 08:16 AM
Alfredg94
Feb 26, 2016 02:12 PM
SweetChinMusic
Feb 18, 2013 08:26 AM
BOTAN01
Jan 10, 2008 12:48 AM
Pretegra
Aug 13, 2004 01:26 AM
