1990 Honda Accord 2.2L Ex Near Overheat
So as the title says, yesterday when going to pick my girl up from work getting out of the freeway i saw that it was a lil warmer then usual then IT WAS ABOUT TO CLIMB and killed the engine, turned the key back to II so the fans can kick in and it started falling really quick, both fans were running i let the car cool and picked up my lady, it was cool enough and it was right around the corner from her work, so took it to my moms pad only a block away. completely let it cool down opened the radiator cap and no water is missing, it was full seemed strange so i let some of the coolant out and behold *rubber like substance* in the radiator i think we all know what that means. before i bought the car someone put some headgasket stop leak, so i go ahead and turn the car on and bam bubbles !!!GREAT!!! LOL so i put the fans on direct power made it home. so now im at a bill of $400 for radiator,cap, radiator hoses, thermostat, headgasket, intake manifold gasket and gasket valve cover will be doing it this weekend so honda-tech be ready my first time documenting something on here. ive already cleaned the egr ports took out my manifold to do this cleaned it very very very very damn good when i shined an led inside the egr valve port i can see all holes nice and clear hell yeah hahaha. THIS CUT INTO MY TURBO BUILD BIG TIME. LOOKS LIKE ILL BE WAITING EVEN LONGER
no thermostat at that point, I replaced coolant, flushed head and block put thermostat in oem oem radiator and now she runs cooler, the old coolant i took out did look brownish and after i emptied it it had like rust settled at the bottom or scales very MINIMAL but i had the original radiator inspected and cleaned, it couldn't be saved it was far gone i will be going toward the end of this year going turbo with forged internals
and i can dump 4-5k into this car full suspension, brakes, fluids, mounts, tune up, couple vital sensors, bushings, timing belt, water pump, radiator, thermostat, engine seals and now im set for a good as while
Well there's always carfax and asking for service records. Usually the car has been well maintained when the person has those instead of them rambling on about how a bunch of parts were replaced. Pretty easy to check these cars to see if they're good mechanically. For sure if it's still got a good body and relatively decent interior for it's age. Just comes down to if you're content with that car for years after sinking that much money into it.
DTvn
Mar 30, 2015 07:54 PM
summertimehonda
Jul 11, 2012 01:32 PM
Valvador
Honda Civic (2001 - 2005)
17
Aug 25, 2011 02:00 PM
