Rings gone/going can i "bandaid" this. 94 b18c1
Old May 14, 2013 | 08:10 AM
B_Swapped93's Avatar
Default Rings gone/going can i "bandaid" this. 94 b18c1
Car ran super rich for a long time and washed the walls pretty good. have determined this via a wet comp test and ppl saying this. comp dry is 210-220 1-4 wet test is 300,240,280, and didn't do #4 wet. my question is can I "bandaid" this by milling the head .015-.030 I know a rebuild would be ideal but I don't have the know how to pull the engine plus this is my DD. car is getting tuned this Thursday so i'll see what it puts down. comp was at one point 240-239-238-240.
Old May 14, 2013 | 08:51 AM
TheShodan's Avatar
Moderator
Default Re: Rings gone/going can i "bandaid" this. 94 b18c1
Milling the head wouldn't help you at all. Has nothing to do with the piston rings themselves. Call and cancel your appointment, and reschedule once you get the block back out with new piston rings.
Good luck.
Old May 14, 2013 | 09:21 AM
Rocket's Avatar
Run non-detergent (ND) 30wt. You can get it at Walmart or some of the smaller autoparts store.
Change your spark plugs.
Lesson, here is don't run on a shitty basemap; IT WILL HURT YO MOTOR.
Old May 14, 2013 | 09:26 AM
Good luck.
was thinking more along the lines of upping the comp which it would do. I really don't have enough to pay someone to do it. and I can't be without a car for the amount it would take me to rip the engine apart. MAP was reading wrong wish I had caught it sooner
Old May 14, 2013 | 02:12 PM
I think i'll just go threw with getting it tuned maybe mill the head .015 or something and when I know how i'll pull the engine and start messing with the internals.
Old May 14, 2013 | 05:30 PM
m_shake's Avatar
I don't see the point in "upping" the compression if its just gonna leak past the rings.
Old May 14, 2013 | 06:16 PM
TheShodan's Avatar
Moderator
Getting it tuned will just make things worse, because he'll try and tune it off of a bad engine. Most tuners won't ALLOW the car to be on there KNOWING something mechanically is wrong with the engine. You'd waste even more time and money.
Mechanical issues can't be tuned out. I don't know where this logic came from, but i'm seeing it more often.
Old May 14, 2013 | 06:51 PM
I see your and others point on that. Can I pull the pistons WITHOUT removing the engine I have ramps jacks and plenty of tools im just to scared to even try and remove the whole engine.
Old May 14, 2013 | 07:26 PM
Zaraki's Avatar
Rocket, what's the benefit of running non detergent?
Is there a specific spark plug you recommend?
Old May 14, 2013 | 07:58 PM
Rocket's Avatar
Gonna help it break in again. ND is pure oil with no additives, including antiwear additives.
Old May 14, 2013 | 08:23 PM
egb18c5's Avatar
if your removing your cylinder head, then you already did most of the work. the block can stay inside the engine bay as you remove the pistons/rods
Old May 15, 2013 | 11:14 AM
Dark_Teg's Avatar
Your dry compressions numbers are similar to my B18C. I am curious how you did your wet test. 300 is way high, makes me think you put to much oil in the cylinder and your wet numbers are worthless. I would pay someone to do a leakdown test before you tear your motor down.
Old May 15, 2013 | 11:47 AM
how much oil am I supposed to put in ? I poured from a 1qt can maybe a "shots" worth or more went in. I will be pissed AF if I did this wrong have already canceled my appt !!!!. was thinking the same on the leak down test I just need a compressor
Old May 15, 2013 | 01:49 PM
Dark_Teg's Avatar
You are supposed to use the 1 Qt oil bottle cap and poor one cap full into the cylinder. A shots worth is way too much. I bet your motor is fine.
Old May 15, 2013 | 03:19 PM
ya I dumped about 4-5 times that in lol. last time I did a wet test it rose by 5-10psi. that's why I was so schocked. will re do when I've ran the engine a good bit and only use a cap\s worth in each cyl.
thanks
NOTDISFA5
34
Oct 10, 2010 12:01 PM
crashsvg
Jan 8, 2010 03:21 AM
climb_on
16
Sep 5, 2007 08:49 PM
PrettyFastRide
Aug 24, 2006 10:24 PM
gutted
31
Jun 6, 2006 12:05 AM
