b20b swap in crx
i have a obd2 99-00 b20 with b16 cable trans. if i am converting to obd1, can i use a obd0 ls intake manifold and swap over the throttle body, fuel rail, injectors, iacv, map, tps, iat, etc... from my obd2 crv intake manifold? i planned on using obd1-obd2 injector adapters, dizzy adapter, and alternator adapter cause i have a rywire obd1 engine harness
Distributor and 4-wire O2 sensor are the only sensors that I'm aware of that are OBD specific.
You should be able to use the complete intake manifold from the OBD0 motor - sensor and all.
Injector adaptors are a waste of money unless you really have ZERO ability to modify your OBD0 clips/harness.
You won't need them anyway if you are planning to use the LS manifold.
Just use the LS injectors and a resistor box.
The B20 injectors are 245cc and the LS are 240cc.
Should run perfectly fine with your LS ECU.
You are HOPEFULLY getting the motor tuned anyway so it's all good in the hood.
Blaze45
Aug 22, 2002 02:28 PM
