1996 DC4 coupe fuse box/turn signal harness removal help
Old May 13, 2013 | 08:25 PM
lolv8s's Avatar
10 Year Member
Icon2 1996 DC4 coupe fuse box/turn signal harness removal help
I'm about 3/4 of the way done stripping down my engine bay to paint. The only problem I've encountered is trying to remove the passenger side wiring that goes through the firewall into the cabin. I was wondering if there is an easy way to get it disconnected without ripping the whole dash apart. This isn't something I can just tape around anyways because I have to replace it. The owner before me tried to do a wire tuck and turned the wiring into a chopped up cluster ****. I've done a lot of searches and haven't really found anything relevant to what I'm looking for. Help is much appreciated. Here's some pics to give you a better idea of what I'm talking about.
Old May 14, 2013 | 01:05 PM
lolv8s's Avatar
10 Year Member
Default Re: 1996 DC4 coupe fuse box/turn signal harness removal help
No input from anyone? Somebody help me out lol
Old May 15, 2013 | 08:47 AM
CleanLikeJdm's Avatar
Hype-R Stalker
It's part of the underdash harness. Not much way around it. And it is all one piece.
Old May 15, 2013 | 01:16 PM
lolv8s's Avatar
10 Year Member
Can't I unclip it somewhere from under the dash? The drive side just unclipped and I pulled it through the whole in the firewall.
Old May 15, 2013 | 06:49 PM
B_Swapped93's Avatar
can you take a further back pic of the harness in the engine bay ?
Old May 15, 2013 | 07:42 PM
Hype-R Stalker
No, only the driver's side unclips from the brown/gray plugs.
It does not unclip anywhere in the harness, it's all one piece.
Old May 15, 2013 | 08:02 PM
lolv8s's Avatar
10 Year Member
So would my best best just be cutting it all off at the firewall and then get another harness from the junkyard (not all fucked up like mine) and then just splice it on there?
Old May 15, 2013 | 08:07 PM
lolv8s's Avatar
10 Year Member
Old May 15, 2013 | 08:09 PM
lolv8s's Avatar
10 Year Member
Forget what I said a minute ago the plugs that go to the engine harness are fine as well as the plugs that go to the fuse box. Id just cut the turn signal part off and splice a new one on. If that would be my best way to do it...
Old May 16, 2013 | 06:29 AM
Hype-R Stalker
If you can just replace mangled plugs, you'd be much better off.
Is there anything that doesn't work at all?
The way it's set up now, if everything reaches it'll work fine.
Old May 16, 2013 | 12:59 PM
lolv8s's Avatar
10 Year Member
It should all reach but there are plugs that have wires cut up and stuff. Like some plugs are missing wires to them.
Old May 16, 2013 | 01:54 PM
Hype-R Stalker
The plugs that are running outside the engine bay should be
-Head lights hi/lo
-Turn signals(2 plugs)
-Horn
-Large plug for the radiator fans
What I can think of off the top of my head, should be all of them.
If there are any specific plugs you need colors for, I have harnesses I can look at.
Old May 17, 2013 | 04:33 AM
lolv8s's Avatar
10 Year Member
If you could tell me the colors of the plugs on the outside of the engine bay for the passenger side that would be awesome
Old May 17, 2013 | 06:48 AM
fcm's Avatar
fcm
Old Fart
Why not just pull it all into the pass. compartment? 94
Old May 17, 2013 | 12:48 PM
Hype-R Stalker
So from top to bottom, it should be ...
-Highbeam/Lowbeam
-Large bulb turn
-Small bulb turn
-Horn plug
-Rad fan/ac fan
-Rad fan power(2wire)
If you can't tell the colors of any wires, lemme know.
Old May 17, 2013 | 04:46 PM
lolv8s's Avatar
10 Year Member
What do you mean?
Old May 17, 2013 | 04:48 PM
lolv8s's Avatar
10 Year Member
-Highbeam/Lowbeam
-Large bulb turn
-Small bulb turn
-Horn plug
-Rad fan/ac fan
Thanks man. What kind of chassis was this turn signal harness in? Will it be the same as my dc4? Or is this a dc4 harness?
Old May 17, 2013 | 05:20 PM
Hype-R Stalker
The 3-wire plug is just the part that disconnected from the bulb socket.
But yes, dc2-4 are the same with headlights/turnsignals.
fcm's Avatar
fcm
Old Fart
What do you mean?
If you want to get your harness out of the engine bay so you can paint, just pull it all in to the pass. compartment through the hole in the firewall.
I see what you mean by damaged wiring/plugs, if it was me I would find a good one at a PicknPull and just replace the whole thing. 94
coolguy660
Aug 30, 2006 09:45 PM
dkk119
Apr 27, 2006 10:48 AM
eagleclawracing
Jan 17, 2006 08:51 PM
Shawn C
Dec 13, 2005 07:13 AM
McLovin
Aug 1, 2005 11:10 AM
