Transmission & Drivetrain Gearboxes, Differentials, Clutches
Stick moves when in gear
Old May 13, 2013 | 05:46 PM
m.glisson003's Avatar
Default Stick moves when in gear
Working on a 1990 Acura Integra with B18 Non Vtec.
Firstly its really hard to get it into gear. You have to put alot of force onto the stick to get it into a gear.
My main concern is that when I put it into a gear the stick still moves around like its in neutral. BUT its still in gear.
Anyone know why this is happening?
This is my first time dealing with a cable clutch
Old May 16, 2013 | 07:30 AM
sleepyaccord96's Avatar
Default Re: Stick moves when in gear
Shift linkage is worn out,
Where the linkage hooks to the trans there is a joint there where a roll pin (bitch pin) keeps it intact. That joint is most likely worn out from age and milage.
You can get a Mil spec 3/4" x 3/4" non splined joint at summitracing.com and cut out your old floppy joint and weld this one in that provides a no slop shift linkage.
Old May 16, 2013 | 07:37 AM
JuggerNaut-CTR's Avatar
Bushings from the linkage to the shifter and bushings under shifter have probably seen better days as well
Old May 17, 2013 | 01:50 PM
Thanks guys. I will look into getting that replaced.
jumpin4abeat
Jun 30, 2011 06:55 AM
eghatchfla
Jul 28, 2010 06:28 PM
civic92si
Mar 31, 2007 08:34 AM
BrokenLimits
11
Dec 7, 2005 09:34 AM
swiftstyles
Nov 24, 2004 09:52 AM
