Integra part out
I am parting out my 99 LS that was wrecked on the front passenger side. I also have a bunch of left over parts from Integras that I have accumulated over the years. Everything must go. I'll update it as parts are sold.
shift linkage with hardware and short shifter (shifter boot is a little ripped)-$90
manual transmission t-bracket with rear mount and energy suspension inserts-$75
taffeta white oem trunk with no spoiler (It has the third brake light and plastic panels on it in very good condition. The rubber seal and glass are in very good condition. The wiring is intact and uncut. The emblems are still there and in very good condition. It needs to have the tint taken off of it and may have a light ding or two.)-$100
taffeta white oem door and quarter panel moldings (There are in good condition overall. The driver and passenger side moldings are in very good condition. One quarter panel molding had the clip mount distorted a little bit but nothing major. They may need a clip or two)-$80
front oem ppg window with tint excellent condition!-$100
rear bumper reinforcement beam-$30
LS throttle cable-$20
rebuilt manual transmission OBD2 b series starter-$50
rear seat belts-$25
turn signal and wiper switches-$30
Tanabe exhaust and custom made test pipe (the piping and resonator are all in really good condition. The muffler was bent in the wreck. $60 for a magnaflow and the cost of a welder to weld it on and you have a good aftermarket exhaust for cheap-$200
ignition assembly, door handles with key cylinders, glove box handle with key cylinder, trunk key cylinder, one factory oem key, and one aftermarket key-$175
passenger and driver side door lock actuators, door lock module, and door wiring harnesses-$125
manual pedal conversion kit with switches ( The rubber pedal covers are in excellent condition.)-$80
00 GSR power steering pump with aem pulley-$50
front and rear disc brakes with brembo rotors and axxis pads (front 20%-30% life, rear 40%-50% life), abs sensors, e-brake cables, bolts, control arms, trailing arms, and everything you see in the picture. Some bushings and ball joints may need replacement. The rear swap looks good. The front passenger side was what was damaged in the wreck. The front looks good too but just want to inform the potential buyer-$250 for all of it
abs 40/40 proportioning valve-$40
98-01 abs modulator pump-$50
power steering rack and pinion-$30
front and rear sway bars-$25 a piece
passenger side vent-$25 shipped
one trunk strut-$10
underhood relay box-$20
abs relay/fuse box with battery cable-$20
abs computer-$10
steering column-$50
blower motor-$20
srs wiring-$10
dash wiring-$40
moonroof-$50
fender (just some surface rust)-$20
GSR transmission-best offer
The case was damaged in the accident. It appears that one of the synchros were damaged and probably a shift fork too.
bare 2000 P72 GSR head (No cracks or damage. I started to deburr the intake ports but lost interest. Perfect core head to build)-$50
2 Falken Hanabi 15 inch 4x100 rims (They are discontinued and don't have a single curb mark on them. Tires were brand new S.drives but may have been scuffed in the wreck. The other two rims were bent. Hopefully somebody needs an extra or two since they are discontinued.)-$100 for both firm
dead pedal-$5
cruise control steering wheel switches and cover-$10
auto cruise computer-$10
cruise control actuator-$25
cruise control and dimmer switches-$5 each
gas door-$10
hood prop-$10
radiator cap-$5
evap purge solenoid (under gas tank, probably pressure sensor too. Not sure I'd have to look it up)-$40
fuse box off of a 00 GSR-$20
door dome light switches-$10 a piece
autometer oil pressure gauge and bracket-$50
fuse box cover with diagram-$10
dome light-$5
map light-$5
[img]https://i280.photobucket.com/albums/kk162/vshavoc/car%20parts/023.jpg[img]
trunk light-$5
clock-$5
056700-7330 relay (2 of them)-$10 shipped
056700-8570 starter relay-$10 shipped
mitsuba RC-2201 relay-$10 shipped
rear seat belts-$25
one trunk strut-$10
abs computer-$10
steering column-$50
blower motor-$20
srs wiring-$10
dash wiring-$40
moonroof-$50
dead pedal-$5
gas door-$10
hood prop-$10
radiator cap-$5
dome light-$5
map light-$5
trunk light-$5
clock-$5
I have an older tanabe exhaust that come off of it. The muffler got a bit bent up though in the wreck. The piping is all still in really good condition though. I ran it with a 00 GSR catalytic converter and a 00-01 DC header. It'll work with any Integra but you have to run the right length manifold and cat combo if I remember correctly. When I bought the car it had the exhaust on there and was running an aftermarket cat that was the 99 length but my header wouldn't fit so I took the cat I had off my 00 GSR that got rear ended and it all fit in there fine. If you're using the 94-99 cat and manifold, or the 00-01 cat and manifold, it should bolt up with no problem. I'm gonna post pictures of it soon and take any reasonable offer. I'm just about finished stripping the car too so alot more stuff will be posted soon.
I'm going to put that all together tomorrow and post it up as a complete kit. It'll have the ignition switch and cylinder, both door handles with key cylinders, trunk key cylinder, glove box handle and key cylinder, with one oem acura key and one aftermarket key.
I see on the sold listings on ebay that a few sets of ignition, trunk, and door cylinders with keys sold for $130 shipped. I'm thinking I'm going to ask $175 shipped for the ignition, trunk key cylinder, glove box handle with key cylinder, door handles with key cylinders, and two keys. I can do $140 shipped if I remove the cylinders from the door handles and sell the handles seperately.
