s2000, integra, Civic, RSX, prelude parts GALORE!!
Ap1 F20c complete engine swap with accessories
was running when removed but had knock
Spun bearing, come with transmission, clutch, flywheel, alternator,
wiring harness, starter, injectors, coil packs, exhaust manifold, intake manifold
$1600 (will part out engine swap if i get many interested)
Volk Racing CE28n
17x9.5 + 47
$400 for one rear
OEM softop latches
$110
Veilside Tonneau Cover
Authentic
Berlina Black
$250
Complete AC system from AP2 low miles
AC compressor, condenser, lines, evaporator,aux fan
$300
AP1 complete softop set up
frame, motors, brackets, drain plastics
softop in great shape no tears or wear
plastic rear window with normal yellowing.
$280
Ap1/Ap2 soft top tray 4 pieces complete
$60
Ap1/Ap2 center plactic
top of windshield with map lights
$40
Custom Fiberglass 12" subwoofer enclosure
with Audionbahn subwoofer. It is made for the tool kit area
Carpeted to match the trunk interior
with MTX amp and amp mount in spare tire area
$320
00-09 interior door handles
all black left and right
$25
00-09 interior plastic door handle trim
$15
Ap1 exhaust tips
$30
Ap1 rear subframe
$125
Ap1/Ap2 front subframe
$125
Ap1 driver rear upper control arm
$50
Ap2 EPS module
$60
Ap1/Ap2 passenger side engine bay fuse box
$40
Ap1/Ap2 driver side engine bay small fuse box
$20
Ap1/Ap2 OEM exhaust shield
$45
Ap1/Ap2 GPW passenger side mirror
$50
Ap2 ABS pump
$60
Ap1/Ap2 wiper motor and mechanism
$25
Ap1/Ap2 battery metal tray with plastic tray
$20
Ap1/Ap2 hood hinges
$20
Ap2 radiator fan
50
Ap1 fuel rail
$20
ap1/ap2 belt tensioner
$40
00-09 ap1 ap2 passenger headlight brackets
$40
04-05 SRS air bag reel
$40
00-03 srs air bag reel
$35
Ap1/Ap2 coolant reservoir
$35
AP1/Ap2 windshield washer reservoir
$30
Ap1 rear driver side tie bar
$25
AP2 cruise control set up
$35
AP2 lower portion trunk interior carpet
$20
AP2 ebrake handle
$35
s2000 power window switches
$45
S2000 upper front bumper bracket
$15
96-00 Honda Civic EK
power window conoversion
dark grey door panels with red inserts (CTR look)
floor harness, door harness, window switches,
window regulators, window motors
$250
00 B18c1 gsr Valve Cover
oem wrinkle black mint condition
$75
99 B16 Civic Si Valve Cover
began stripping it
$50
Mugen front strut bar
fits integra and civic
good condition missing sticker
$100
rear strut bar for EK civic 96-00
"Mugen style"
$60
P72 GSR B18c1 OBD2a Ecu
$70
90-93 Integra B series
rear L bracket
perfect for B series swap in EF CRX and Civic
$40
Walbro 255 fuel pump
with 94-00 fuel sender assembly
straight drop in
$75
RSX 03 OEM headlights
no broken tabs in good condition
$100
Neuspeed lowering springs (green)
with oem shocks and top hats
for 97-01 Prelude base
$100
99-00 Civic SI
Greddy DTM axle back
direct bolt on
new in box
$125
02-05 RSX type S
direct bolt on
new in box
$125
Volk Racing CE28n
17x9.5 + 47
$400 for one rear
OEM softop latches
$110
Authentic
Berlina Black
$250
$300
$280
$60
$40
$320
$25
$15
Ap1 exhaust tips
$30
Ap1 rear subframe
$125
$125
$50
Ap2 EPS module
$60
$40
$20
$45
$50
Ap2 ABS pump
$60
$25
$20
Ap1/Ap2 hood hinges
$20
Ap2 radiator fan
50
Ap1 fuel rail
$20
$40
$40
$40
$35
$35
$30
$25
$35
$20
AP2 ebrake handle
$35
$45
$15
$250
$75
began stripping it
$50
$100
"Mugen style"
$60
$70
rear L bracket
$40
straight drop in
$75
$100
$100
99-00 Civic SI
direct bolt on
new in box
$125
02-05 RSX type S
direct bolt on
new in box
$125
Can you send me a picture of the front strut too if you don't mind. famousmaxpowers@yahoo.com
