1990 civic hatch trouble starting
Old May 12, 2013 | 04:04 PM
Steveramirez21's Avatar
Default 1990 civic hatch trouble starting
I have 1990 civic hatch It cranks but won't start what can be some problems It has new batteries and it has fuel pressure I check it with the fuel filter what else can I check
Old May 12, 2013 | 04:26 PM
tmurph's Avatar
Default Re: 1990 civic hatch trouble starting
is it manual if so make sure the pedal is pressing the safety switch on the pedal assembly make sure you have good ground cables
Old May 12, 2013 | 05:36 PM
sstupid's Avatar
10 Year Member
Old May 12, 2013 | 05:54 PM
Tim512001's Avatar
check for spark, if it has spark and fuel through filter check injectors.
Posted from Honda-tech.com App for Android
Old May 12, 2013 | 11:08 PM
jdm_rb20's Avatar
In the original post, he said it "cranks but wont start" so it's not the clutch safety switch. That's the first thing that came to my mind also.
To the original poster, what were the last "conditions" when the car stopped working? ie, driving down the road, parked for 2 years, just wont start one day, or maybe you just did some routine maintenance that might be a clue?
Just some tips for "crank but no start":
#1 MOST IMPORTANT!!: Do you have any check engine codes???? If not, try to crank it for a solid 30 seconds and see if a check engine code shows up. (but its usually safe to ignore the "injector code" if you are turning over a no-start engine).
Then, after checking out any codes, consider the following......
Fuel pumping does not mean the pump is strong enough to start and idle..sometimes they prime but don't have constant power or consistent flow.
Same with spark: having a spark from screwdriver to chassis doesn't mean it is strong spark. look for a solid blue color of the arc...not yellow/red. causes: dizzy, rotor, cap, or sparkplug wires.
What do your spark plugs look like?
Major vacuum leak, especially around the EGR (personal experience/headache)
Need proper compression: If ALLL else fails, get a compression test.
Old May 13, 2013 | 10:36 AM
It is manual do you have a picture where exactly the ground is at??
Old May 13, 2013 | 10:37 AM
I'm check the spark tomorrow after I buy the ignition tester
Old May 13, 2013 | 10:40 AM
It was working fine but 2 weeks ago it will start and eventually it will stall and then later it stop running. I have check the fuel pump, main relay, fuses, I check the pressure with fuel filter and tomorrow ill be checking the spark
Old May 13, 2013 | 05:22 PM
jdm_rb20's Avatar
Check your fuel pressure with a fuel pressure gauge or sometimes you try the following:
--increase fuel pressure by physically pinching the fuel RETURN line...meanwhile have someone else try to start it and keep it idling. Don't rule out fuel just because it squirts, even if it is strong. :0
Old May 14, 2013 | 06:38 AM
Okay I have check the spark and their no spark where do I go from their???
Old May 14, 2013 | 09:08 AM
89c1vicSi's Avatar
what safety switch?? its obd0 they didn't have a safety switch till 92 I believe. because every civic iv been and worked on 88-91 has not had a safety switch no matter what model it was. and I see a lot of civics.
Old May 14, 2013 | 09:23 AM
4drEF's Avatar
Keyboard Humorist
"OBD" doesn't care if you have a safety switch or not.
OBD deals with the sensors on the engine that relate to emissions... nothing to do with safety switches.
This year of Civic/CRX do have a switch that contact the top of the pedal under the dash.
It is common for a small plastic stopper to break off and then the switch does not actuate.
There are several fixes for this including buying a new stopper or even just JBWelding a penny over the hole.
Old May 14, 2013 | 10:30 AM
89c1vicSi's Avatar
what im saying is iv been in and worked on every trim and model and have not seen 1 safety switch, my pedals no are from a 90 crx and it doesn't have a safety switch.
Old May 14, 2013 | 10:38 AM
89c1vicSi's Avatar
Uploaded with ImageShack.us
ok I may be wrong but just sayin out of all the civics iv driven and worked on not one has had a safety switch lol but if ur not getting spark, its problem with dizzy or dizzy wiring, or as stated the main relay, take it out and reflow it, meaning make sure all solder points are good and solid and no tiny cracks. it takes the tiniest crack to mess things up
Old May 14, 2013 | 10:59 AM
4drEF's Avatar
Keyboard Humorist
Well, you are partially right.
88 for sure did NOT have the switch.
90 and 91 for sure have it.
89 supposedly has it, but a few people claim they don't. (I haven't seen 89 to know one way or the other.)
Old May 14, 2013 | 11:05 AM
89c1vicSi's Avatar
I have a 89 and so did a friend in az and his was 5spd stock and no safety switch, iv seen a few stock 90 hatchs with none either but idk lol. I do admit I was like u said partially wrong, I apologize. but op seems to have dizzy issues, maybe try swapping out for known good dizzy and try it.
Old May 14, 2013 | 01:22 PM
jdm_rb20's Avatar
^^+1 I can confirm that my 90 and 91 civics have a clutch safety switch because I have had to replace the flimsy plastic piece in both with a nut&bolt.
but we KNOW it's not a clutch safety switch issue:
I would still like to know if he has any ECU codes. If he has no spark, I would definitely want to see if an ECU code will pinpoint the problem for me. Or also, does the ECU have power?
Theoretically, I am trying to think of a problem that can start slowly as he described.....corroded or loose grounds can prevent electrical equipment from functioning properly. As they get more corroded/loose, the problem will get consistantly worse.
Don't spend money throwing parts at the problem until you properly troubleshoot to find the cause.
Old May 14, 2013 | 02:12 PM
89c1vicSi's Avatar
I was sayi if he knows someone with a workin dizzy try it, not go out an buy one without knowin first. an yes I was wonderin that bout the ecu aswell
Old May 15, 2013 | 06:00 PM
tmurph's Avatar
I found a lot of people just wired it on all the time seen done in may car iv pulled parts off in junk yards and yes what he said on checking it...
Old May 15, 2013 | 07:48 PM
Son2BEHO's Avatar
Have you tried switching out main relay?
also check for good connection/no green inside cables on battery to frame ground and frame to tranny and valve cover to radiatior support and thermostat housing
Old May 16, 2013 | 11:43 AM
Trevor123456789's Avatar
i agree mine was doing the exact same thing i changed the main relay and the igniter module and my car runs great.
Old May 18, 2013 | 10:16 AM
sstupid's Avatar
10 Year Member
Definitely the main relay. Just don't break your dashboard, like I did, trying to get it out. Doh!
mikeliterus
Apr 7, 2010 09:32 AM
mangodade
Mar 18, 2010 05:30 PM
camp_kill_yourself
Apr 20, 2007 09:31 PM
classciv
10
Jan 17, 2006 06:37 AM
G2LSVtecTeg
Nov 22, 2005 04:03 PM
