annoying exhaust rasp. ugh...
Old May 12, 2013 | 06:27 AM
blackeg's Avatar
Default annoying exhaust rasp. ugh...
i think we all know that bllllaaaattttt raspy/ tin rattling sound that honda exhausts can make. i just cant believe im having problems with it. worst part is it happens between 2500 and 3000 rpm so i pretty much cant avoid it.
motor is a b20b. exhaust is a edelbrock header with collector mod, 2.25" magnaflow cat, 2.25 vibrant flex section, 2.25" vibrant resonator 18" length placed in the middle of the mid pipe, 2.25" magnaflow straight through muffler. the piping itself is a kteller weld up, again 2.25"
with the cat, resonator, and only 2.25 piping i figured it wouldnt make that noise.
would an exhaust leak really make it worse? theres a small chance that flex section is **** and leaks a bit. how can i clean this up, i like the sound of the exhaust besides this noise
Old May 12, 2013 | 12:11 PM
blacK_Dc4's Avatar
Default Re: annoying exhaust rasp. ugh...
u might want to go with a different muffler, possibly one that is not straight through. it's funny, but I can tell u that different headers actually creates a different tone.
Old May 12, 2013 | 12:46 PM
B_Swapped93's Avatar
sounds like a leak where check the flex section first. could also be something lose rattleing around look into those first
Old May 12, 2013 | 02:25 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Got a cold air intake or short ram? I have a gsr swapped hatch w 60mm yonaka WS-2 catback with plm hytech header. I added a cat then a 24" dynomax bullet resonator and still couldn't get rid of the rasp. I replaced my cold air intake for a stock ITR box and tube and zero rasp now. The resonance caused by the smooth tubing of a cai or Sri is enough to cause the rasp you hear.
Old May 12, 2013 | 03:35 PM
TheShodan's Avatar
Moderator
Sounds like the baffles in the resonator or muffler could have rusted out, if you are now noticing it, and it wasn't that way originally. A "rasp" would be from an exhaust leak, that has a distinct sound.
Old May 12, 2013 | 05:34 PM
blackeg's Avatar
everything is brand new. i just welded it up a few weeks ago. its been like this from the get go. i used one of these magnaflow mufflers on my old all motor b20 with no twanging rasp, but that was a 2" not 2.25:...
currently just using a short ram 2.5" intake. this is just temporary until i put in my lsvtec and make a 3" intake for that motor.
Old May 12, 2013 | 06:39 PM
Rocket's Avatar
Straight-through mufflers sound like that. Perhaps try a mellow sounding Flowmaster.
Old May 12, 2013 | 07:51 PM
koczeka's Avatar
If the resonator is not filled well (I mean burned out) it is raspy... he should check... easy fix.
Edit: lol, it is new
Then it is not sized properly.
Old May 13, 2013 | 08:21 PM
gstrudler's Avatar
OP just said everything was brand new, so that's unlikely.
My money is on a leak. If you have a welding shop nearby, you can buy a leak-detection liquid that you can squirt on the joints and it will bubble up if you have any leaks (while the engine is running of course). Soapy water can work in a pinch too.
Old May 13, 2013 | 10:13 PM
DazeMS's Avatar
its from your resonator. Its not capable of resonance at that rpm's frequency. Think of a reed in a wind instrument. When you over power the reed, you are exceeding its resonant response and under powering the reed , you are not meeting the resonant response. either end of the frequency will cause resonate frequencies to be uncontrollable ones.
Placement, length and type of material in a resonator makes all the difference. Cheap "muffler/resonator" types use fiberglass and a tube with holes in it. Quality "resonators" are made with a ruffled tube with holes and stainless steel mesh.
Old May 18, 2013 | 08:13 AM
flysocietylano's Avatar
sounds like a leak. was having the same annoying rasp sound and got it checked and it was that. god luck finding out what it is though.
Old Dec 27, 2013 | 06:32 AM
dmemenza's Avatar
10 Year Member
reviving this thread from the dead....I have a 98 Integra. Exhaust has always had a raspy sound. Thought it was just the resonator, but the dealership told me I have a header collector leak. I don't think they make collector replacements, so my only bet is to get a new set of headers or a good weld job? Would that be accurate?
Thanks,
- DM
Old Dec 27, 2013 | 11:34 AM
93egSLEEPER's Avatar
That post can be taken 2 way.
1)There is a leak at the collector as in the gasket is broken/no good
or
2)the header is actually broken/cracked
Which is it?
Old Dec 27, 2013 | 05:29 PM
dmemenza's Avatar
10 Year Member
^ I wish I could tell you. All the dealership told me was that I have a header collector leak. They wrote on the multi-point insp sheet "header collector leak" & marked it "may require future attention". I just assumed he meant the actual collector part of the header. If it were gasket, I would think they would write down "gasket"...perhaps? It probably wouldn't have hurt to confirm. They also said noted on the insp sheet that I have a small oil leak and the mechanic wrote "oil pan gasket"...see what I'm saying? Again, it probably wouldn't have hurt to confirm. Your point is valid, I just assumed from all the stuff that was written down.
- DM
switched_in_your_eye
Honda Civic (2006 - 2015)
17
May 2, 2009 05:44 PM
axtran
May 27, 2006 12:15 PM
jvschlegel
Aug 1, 2005 06:14 PM
JonGP4
Jun 30, 2003 12:30 AM
KRNewbie
Mar 18, 2002 07:19 AM
