Oil leaking from head....is it possible?
Old May 11, 2013 | 10:05 AM
Gemar's Avatar
Default Oil leaking from head....is it possible?
I have an oil leak, just start down between where the tranny and block meet. Sits on top of the engine code. At first it was my vtec seal, fixed it. Next day still oil but not as bad. Valve cover is good. O ring for dizzy is new. I dont see it coming from under the dizzy. Another builder told me it was coming from the head. Ive heard too many time thats impossible. Whats your experience?
Old May 11, 2013 | 10:14 AM
dafreeeze's Avatar
Default Re: Oil leaking from head....is it possible?
Check your cam seals
Old May 11, 2013 | 10:17 AM
fonkernuckle's Avatar
My experience on sohc: valve cover,vtec solenoid or dizzy o ring, I use a thin smear of gasket maker on the solenoid and especially valve cover.
On a Dohc:same except add the "plug" at the end of the exhaust cam on valve cover.
The vtec solenoid leak sure makes it look likes coming from the head
Old May 11, 2013 | 01:10 PM
Gemar's Avatar
I wiped everything down and let it run for about half an hour watching everthing pertaining to possible leak areas. Didnt see any trickle. No drip from the dizzy, no drip from valve cover, no drip from solenoid. Im sure if it was the head leaking i would have seen it leak within no time. But nothing. I found a needle size hole in my radiator hose bubbling so i put rtv to seal it. Hopefully its that.
Old May 11, 2013 | 01:30 PM
dafreeeze's Avatar
Is the leak oil colored or green lol
Old May 11, 2013 | 01:32 PM
dafreeeze's Avatar
Did you check your cam seals behind the dizzy you might have to remove it for a close inspection
Old May 11, 2013 | 05:53 PM
Gemar's Avatar
No its not green lol i shouldve mentioned that. Yeah i checked the cam seals no leaks but ill remove the dizzy if i see the leak again. Just drove it for a bit and havent seen anything yet. So now its the waiting game. Lol
Old May 11, 2013 | 05:55 PM
jbpnoman's Avatar
Did you replace the internal dizzy o ring, or the external dizzy o ring? There are two.
Old May 11, 2013 | 06:29 PM
Gemar's Avatar
It looks like its comming from inside the tranny. I swear nothing else has oil on it but that part Between the tranny case and the block. It starts right at the top tranny bolt and leaks down to the slave selender. Its a new dizzy so that it didnt cross my mind but its possible. Ill check it tomm. But to confirm my first question, it is impossible for oil to leak from the head gasket right?
Old May 11, 2013 | 06:41 PM
dafreeeze's Avatar
Its probably possible but your heads gotta be pretty warped i would think to start pissin oil out
Old May 11, 2013 | 07:47 PM
Gemar's Avatar
Thats what i thought. I would see it asap on start up. But sitting its clean but after a 20 min
drive it shows up.
Old May 12, 2013 | 05:55 AM
dafreeeze's Avatar
Yah man like we said cam seals vtec sol, dizzy seals , valve cover gasket other than that i have no idea and i know your tranny wont be leaking from there lol
Old May 12, 2013 | 06:37 AM
Basik_One's Avatar
Maybe the rear main seal..?
Old May 12, 2013 | 08:01 AM
nealnanoHX's Avatar
It is very possible, if you have a LS Vtec and used a Vtec head gasket. Match the head gasket to the block.
Old May 13, 2013 | 05:46 AM
Gemar's Avatar
I have a d16z6 i replaced rear main seal when i rebuilt the block. Ok went out and started it today Fluid was bubbling at that same spot, where the tranny and block meet. Lol im at a lost here. I tighented it up and whipped it. Ill later after a drive for a leak again.
Old May 13, 2013 | 08:21 AM
Gemar's Avatar
Ok now its leaking from the bolt i tigheten up on the tranny. And deff the corner part of the head. Can i just tourque the two bolts on that side of the head to see if it will stop it? Or do i have to go through the whole new head gasket deal.
Old May 13, 2013 | 09:08 AM
ElectronBlue00's Avatar
Do you have pictures?
Old May 13, 2013 | 10:33 AM
pelayo114's Avatar
Has the motor overheated lately?
Any headgasket work done or in that area?
Also did you get the head and block resurfaced for the rebuild?
Old May 13, 2013 | 11:10 AM
Gemar's Avatar
Motor has been rebuilt, didnt over heat so i figured a good cleaning with steel wool would sufice. But the motors at 250 mile since the rebuild. This is my first rebuild so I guess im learing things the hard way. Lol I can take pictures but im on iphone, dont know how to upload on the website. Inbox me a number and ill text it.
Old May 14, 2013 | 02:10 PM
Gemar's Avatar
Its defiantly my head leaking oil. Can i re torque the head and be safe or do i pull the head and resurface it and slap it back on.
1997accordlx
Jan 7, 2010 12:32 PM
Civic_07
29
Jul 6, 2009 06:05 PM
90CivicDaily
12
May 4, 2008 10:12 AM
Mhollaek9
15
Sep 13, 2007 06:02 PM
ITR_1211
29
Dec 24, 2003 08:15 AM
