Car starts the shuts right back off
Old May 11, 2013 | 04:21 AM
gsmith93's Avatar
Default Car starts the shuts right back off
Need help please don't know much on Hondas but the other day it just randomly shut off on me and had to try to start it a few times before it would stay running did it again yesterday as soon as I pulled in the driveway the check engine light kept dimming out then stalled but this time wont start back up at all just keeps stalling don't have any idea what It could be but power is not going through the car until I try to start it. like the clock and things don't turn on when the key is in the on postion only when trying to start have no idea what it could be tried putting in a new battery but didn't work
Old May 11, 2013 | 08:00 AM
ReaperMan's Avatar
Default Re: Car starts the shuts right back off
icm/coil/main relay/bad connections/ weak,old battery. etc. have you checked the basics before coming here? spark? fuel?
Old May 12, 2013 | 05:43 AM
Lost Again's Avatar
I'm with the elect part of the key switch. Key to on and no clock or anything...humm.
Key to on - get a voltmeter or test light and check for 12v on the BLK/YEL wire at the dist? If none, pretty sure the key switch is bad.
Wouldn't hurt to check/get the codes - you stated the cel was on when driving.
Old May 12, 2013 | 09:36 AM
gsmith93's Avatar
never had this before but if i start it and keep the key all the way forward it will stay on but as soon as the key is back to the on postion it stalls right out
Old May 13, 2013 | 02:37 PM
Lost Again's Avatar
Well you pretty much just confirmed the electrical part of the ign/key switch is bad. Replace the electrical part (not the whole key cyl, just the electrical part) of the ign switch and go from there.
Lamont Rainer
Apr 5, 2016 03:19 AM
Asdfghjkll
Mar 6, 2016 09:59 AM
Parada
Jan 29, 2008 09:47 AM
cbstudd77
Dec 20, 2006 07:40 PM
rodvang
23
Nov 5, 2005 05:57 PM
