valve spring retainer snapped in half. what do i do?!
Old May 9, 2013 | 03:57 PM
luuisss's Avatar
Default valve spring retainer snapped in half. what do i do?!
So i was driving and revved it up to about 5000rpm on 1st gear and the car made a weird noise like i was dragging plastic or something and it instantly turned off and did not start anymore. Didnt crank or anything jus click. Then i opened the valve coverand found a peice of the valve spring retainer right next to the spring just chillen on the upmost left corner. Wtf did i do what should i do how do i fix it?! I have no clue what to do any help is appreciated. I have a 2000 em1 with a jdm b16a. Just i/h/e and everything else is stock. Thanks !
Old May 9, 2013 | 04:00 PM
98ekb18c's Avatar
Default Re: valve spring retainer snapped in half. what do i do?!
Sounds like you dropped a valve. Time for a rebuild/swap.
Old May 9, 2013 | 04:02 PM
luuisss's Avatar
Old May 9, 2013 | 04:03 PM
luuisss's Avatar
Is there any chance of just replacing the retainer?
Old May 9, 2013 | 04:05 PM
luuisss's Avatar
The other half is still stuck on there
Old May 9, 2013 | 04:19 PM
98ekb18c's Avatar
You said the car won't start, it just clicks when you turn the key. Something locked the engine up. You have to take it apart far enough to see what caused this before anything.
Old May 9, 2013 | 05:05 PM
luuisss's Avatar
It wouldnt be the other half peice that i took out?
Old May 9, 2013 | 05:09 PM
98ekb18c's Avatar
Unplug the dizzy and pull the fuse for the fuel pump. Does the engine crank now?
Old May 9, 2013 | 05:18 PM
B_Swapped93's Avatar
Pull the head
but it looks like the valve held in place ? hard to see tho
Old May 9, 2013 | 05:48 PM
luuisss's Avatar
mechanic told me motor is seized so im guessimg i dropped a valve?
Old May 9, 2013 | 05:50 PM
In that case yes i'd say so. though this was just you asking us after having it towed home. pull the head either way it's always neat too see the after math.
Old May 10, 2013 | 08:46 AM
luuisss's Avatar
yeah i will i just got it towed home. You guys think my cams got affefted by the loose peice i took out?
Old May 10, 2013 | 08:54 AM
luuisss's Avatar
This was chillen on top of the nut when i opened it
Old May 10, 2013 | 09:12 AM
S2BumpsticksGSR's Avatar
When was the last valve adjustment?
Old May 10, 2013 | 09:27 AM
luuisss's Avatar
I don't know, i bought the.car a little over a year ago but never adjusted them.
kenpoed
Mar 4, 2014 03:35 PM
GSRpoweredSI
Jul 26, 2007 09:25 AM
sauceja
Feb 24, 2006 07:46 PM
Screamer
Dec 17, 2003 04:41 PM
