Honda CR-V & Element 2WD & 4WD Element & CR-V
2004 CRV- 3rd Cylinder Misfire Code
Old May 9, 2013 | 08:09 AM
Shortyluvsu2808's Avatar
Default 2004 CRV- 3rd Cylinder Misfire Code
The CRV is putting out a 3rd cylinder misfire code but is running and shifting smooth, no other issues with it at this time. The check engine light comes on and off inconsistantly. Replaced spark plugs, came back on. What next?
Old May 9, 2013 | 08:10 AM
Default Re: 2004 CRV- 3rd Cylinder Misfire Code
Also: The front O2 sensor was replaced shortly before this started happening (1-2 months before)
Old May 22, 2013 | 05:40 PM
go-part's Avatar
Have you tested the ignition coil
http://www.obd-codes.com/p0303
Old May 22, 2013 | 05:49 PM
Sticker Bomb's Avatar
Swap the coil with another one and drive untill the code comes back on after you clear it. If it's the coil that's bad, which it most likely is, the code will come back to the which ever plug you put it on. That's how you can confirm if it's the coil or not.
Old May 26, 2013 | 05:03 AM
Almighty-Si's Avatar
To add to the above poster, if you swap coils and the misfire is still in cylinder 3 swap the injectors and run it again. Like the coil, if the code moves when you swap injectors, you know it's a bad injector.
If it still doesn't clear then, move on too a valve adjustment.
Old May 26, 2013 | 05:40 AM
Yeah if you move parts from one spot to another and then give the code for where you just moved it to, that lets you know that that part is no good. Because if it's not that part, it will stay at the same spot as before, so moving one thing did nothing, so you know that part is fine then.
It could also be a bad plug still, even if it's new, they could have been dropped. Also did you check you plug gap before putting them in? Because that will also cause a misfire if the gap is not set to proper spec. It should say what the gap should be on the sticker under your hood.
EL Vap133
37
May 3, 2024 01:13 PM
crum
Oct 10, 2005 06:42 AM
foesicks
Jun 4, 2003 09:47 AM
Damon B.
Jan 19, 2002 02:46 PM
