P0138 code
Old May 9, 2013 | 06:52 AM
Tony_SS's Avatar
Default P0138 code
98 DX, stock engine D16y7 138xxx
I just got this code out of nowhere yesterday.
Backstory, I put on a header, and an inline Magnaflow cat for a Civic EX, the o2 sensors are in the header and after the cat. I used an plug extension to hook up the 2nd sensor. Exhaust is tight no leaks. I've had this setup for over 200 miles... with no issues.
Yesterday I got the check engine light. When I got home I ran the code on my ScanGage II and it gave me P0138. No others. I have cleared it out and driven 20 or so miles, it hasn't come back on.
Also and this may be unrelated, since the code, my idle will occasionaly dip to 550. Normally is has always been 650 or so, at full operating temp. What should it be set at? Is it controlled by the ECU or can I adjust?
Thanks!
Old May 9, 2013 | 06:57 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Default Re: P0138 code
You should have a D16Y7 if it is a 98 DX.
http://en.wikipedia.org/wiki/Honda_D_engine#D16Y7
If you reset it and it did not come back you should be good.
Old May 9, 2013 | 07:10 AM
Tony_SS's Avatar
Yes.. I updated the OP.
Ok... yes I'm hoping it doesnt come back.. it runs great.. good mpg's.. so I guess I'll wait and see..
Thoughts on the idle issue?
Old May 9, 2013 | 07:14 AM
doctorake's Avatar
Community Builder
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faqs-frequently-asked-tech-questions-1998336/
Part 5, L. Air intake and idle control.
Maybe before going down that route you should wait for some others to advise also.
Old May 9, 2013 | 07:19 AM
Tony_SS's Avatar
Thanks... great reference!
Old May 9, 2013 | 07:34 PM
beecee18's Avatar
Thanks!
Your car has become fed up with these after the 200 mile period.
zcmotor
Oct 6, 2013 06:38 PM
spooncivic1
Jun 4, 2007 10:02 AM
justint
Acura TL, RL & ZDX
Feb 7, 2003 02:49 PM
S13 slide
Dec 1, 2002 06:44 AM
