Help rev limiter bypass!!!!
Old May 8, 2013 | 08:11 PM
97uswagon's Avatar
Default Help rev limiter bypass!!!!
Guys I'm in a pickle here I need to find some who will bypass/chip my stock 97 accord Ecu rev limiter I need it to go higher do to my s2s2 pro cams my car tuned in at 165 way lower than my last out put of 175 with basic boltons I just need to know if any body knows anybody here in the ie la region somewere around this area that will be able to do it please help!
Old May 8, 2013 | 08:16 PM
ReaperMan's Avatar
Default Re: Help rev limiter bypass!!!!
what other mods do you have? intake? exhaust? etc?
Old May 8, 2013 | 08:33 PM
97uswagon's Avatar
The motor it self has intake ,headers ,exchaust ,radius valve job,supertech springs and retainers skunk to intake mani aem cam gears gates timing and of course the skunk 2 stage 2 cam shafts
Old May 8, 2013 | 08:35 PM
97uswagon's Avatar
Oh forgot to mention it is all in a jdm f20b sir motor
Old May 8, 2013 | 08:36 PM
ReaperMan's Avatar
and the cams actually decreased your hp? if you think the rev limiter is what caused it. then do a obd2 to obd1 harness get a p28 ecu and chip it. honda, crome, neptune. or go aem ems
Old May 8, 2013 | 08:41 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
I think what he's saying is the cams moved the power band up, but the rev limit wont let it use the power at the higher revs, OP is this a street or strip car? if it's a street car it will drive you crazy trying to drive it with all the power up high, those sound like a race cam
Old May 8, 2013 | 08:46 PM
ReaperMan's Avatar
does sound like a full race car. but with all those upgrades. i think i would of bought an ems or a chipped ecu then do the upgrades and tune. im guessing hes already on chipped ecu since he mentions he got tuned. if its chipped the rev limiter should be removable unless your tuner doesn't know what he is doing
Old May 8, 2013 | 08:51 PM
97uswagon's Avatar
It a street car and auto I just built the head from what I kno I'm the first to test it out on a automatic it's tuned on greasy emanage ultimate
Old May 8, 2013 | 08:53 PM
97uswagon's Avatar
Pretty sure they kno what they are doing and what they are talking about Todd for church automotive tuning and even Sean gave a shot at it
Old May 8, 2013 | 09:01 PM
what are the specs on the cam, what's it's powerband? that sounds like a cam for drag racing, if it is you are going to sacrifice all your street drivability, by moving a lot of your torque into the upper rpm band, it will get old on the street having to rev way up at every light
Old May 8, 2013 | 09:06 PM
from prelude power about this cam:
well pro2s needs pro valvetrain and theyre kinda designed for higher compression than 11
pro1s would be more for your current compression
differences between those cams:
- pro1s are more for DD use and pro2s more for track use
- pro2s move powerband higher than pro1s which max power is around stock red line
- pro2s needs higher compression than pro1s (because max power is in higher rpms than with pro1s)
- pro2s needs stiffer valvesprings than pro1s (you can use tuner valvesprings with pro1s but with pro2s you need pro valvetrain)
- pro2s makes few hp more than pro1s because you can rev higher with them
AND
do you really want to rev over 9000rpm? I mean, the power is then up there and things MAY get unreliable in those rpms (this means that your engines life shortens if you beat it)
+ pro2s need 12 compression to work properly because 11 isnt really enough for those rpms
for DD cars theres no point really imo, pro1s are for dd use, but its your car
Old May 8, 2013 | 09:10 PM
it looks like you would do a lot better for a stage one, especially on a daily driven automatic, you are putting a lot of wear on your engine for just a few horsepower, you can't just put on a cam by going by it's stage, you have to look at it's specs and where it makes power, and see if this fits what you want to do with it,
Old May 8, 2013 | 09:11 PM
97uswagon's Avatar
Fuhhh man I'm kind of stuck with them now so I have to find away to make em work
Old May 8, 2013 | 09:15 PM
but did you build your internals for higher RPM? you can try to bypass the rev limiter, but it's there to keep the stock internals from failing and putting a rod through your block, 9000 plus is a lot of RPM, you have to think about everything inside of the engine, everything from the rods,to the crank, to the hardware holding it together
Old May 8, 2013 | 09:16 PM
you didnt really lose power, you just moved it up high into the rpm band
Old May 8, 2013 | 09:44 PM
97uswagon's Avatar
Correct my vtec doesn't even engage till 65 and my car redlined at 66 man I'm basically fucked dude well guys thanks for ur help if anybody know pm please
Old May 8, 2013 | 09:55 PM
maby you can look for a stage 1 and sell the stage 2 set if it's in good shape? at least not have a total loss
Old May 8, 2013 | 10:34 PM
holmesnmanny's Avatar
You need to upgrade your valve springs if you really want to rev higher than oem. This is a safety issue.
Old May 8, 2013 | 11:28 PM
I think he did, but the internals arent upgraded, that cam moved the powerband up into a range thats pretty useless on the street, it's great if you have a fully built race car going down the track ***** out, but not for daily use on the street
Old May 8, 2013 | 11:36 PM
you're right, sorry I missed that
Old May 9, 2013 | 12:07 AM
yea the stages for a cam are completely different on who makes it, it's application, how many stages etc, you really need to look at a dyno graph of a cam to understand it, or at least understand at what rpm range it makes power, on my car for eg. a stage 2 cam makes power from 2500 rpm to 7000 rpm, but thats on a 27 year old single cam, in my case with all my mods a stage one mild cam would be worthless, it looks like they only make two cams for his application, basically street and race, they might make a stage 3, but I dont know how the power band could be higher then it is, I know some kid who bought the highest stage cam he could get for his 97 civic, with an auto lol, wanted a "race cam" powerband was so screwed the car could barely move at lower rpm, and he would have to rev the **** out of it at lights just to get moving
ActiveAero
Dec 5, 2003 02:45 PM
integraracing91
May 9, 2003 06:16 PM
JDM_Risa
Mar 4, 2003 08:27 PM
Wong Wonder
Feb 28, 2003 08:47 PM
DeDonDeRosa
Aug 12, 2002 08:16 PM
