Correct part # for Oil Cooler Water Pipe
Old May 8, 2013 | 01:16 PM
Mishako129's Avatar
Default Correct part # for Oil Cooler Water Pipe
Hi. I am trying to install an OEM H23 prelude oil cooler for my accord but I can't find the water hose part. They don't list it on the Honda catalog.
This is the kind of part I need, it has the extra passage on the low right side. Even the Honda site lists this part as 19505-PT3-A00 in the Prelude S diagram:
It also lists this which is for my 91' Accord as the exact same part number, 19505-PT3-A00:
I even ordered this part from a company on Ebay and I asked for pics and it was the exact same part I have on my car. I don't know where I can find this part number.
Old May 8, 2013 | 02:47 PM
holmesnmanny's Avatar
Default Re: Correct part # for Oil Cooler Water Pipe
http://www.hondapartscheap.com/parts...p-oil-strainer
part 18
Old May 8, 2013 | 02:57 PM
Mishako129's Avatar
Originally Posted by holmesnmanny
No sir, that's the oil cooler and I have that part already. Its the pipe with the extra coolant passage that I am looking for. I can't find the part number for that and even when I think I do it turns out the part number is the same as the one I already have and its just the diagram that is different. Some dealers use the H23 Prelude diagram which has the same water pipe I need however its for an H23 which won't fit the F22a block.
I will explain this for you easier with diagrams straight from the Honda dealership,
This is for the F22a which I already have, notice the cylinder head.
This is for the Prelude "S" 1992 model. It is supposed to have the F22a cylinder head however this is not for an F22a this is for an H23 woth DOHC,
The water pipe for both of those diagrams is 19505-PT3-A00. So I have no idea where I can find the actual part I'm looking for. The diagram is misleading and the part numbers don't help either.
I tried looking for an EX Accord water pipe on the Honda dealership site but they also only had the 19505-PT3-A00 part. I thought that they would have the one for the oil cooler but they didn't. Maybe you can find it but I can't.
Old May 8, 2013 | 03:04 PM
http://www.hondapartscheap.com/parts...ump-thermostat
part 13
Old May 8, 2013 | 03:11 PM
Mishako129's Avatar
That's a P14 part and its for an H23... it won't fit the F22a block I have the H23 water pipe and a spare block and I already tested it.
Old May 8, 2013 | 03:18 PM
Seriously, what the hell is it exactly that you're trying to find ?
Old May 8, 2013 | 03:22 PM
Only the 90-91 ex wagon and 92-93 ex and se have the oil cooler. Just look at those cars for oil cooler parts. It will be there somewhere.
Old May 8, 2013 | 03:44 PM
Mishako129's Avatar
I guess i'm going to have to modify one with the coolant passage or find a junkyard water pipe. Thanks for the info though, are you sure that is all of the models the cooler came with?
Thanks for trying.
Old May 8, 2013 | 03:49 PM
Mishako129's Avatar
I've tried to make myself clear as possible. Its the water pipe with the lower right water passage for the oil cooler. I'm finding it impossible to find one for my F22a.
Old May 8, 2013 | 03:51 PM
Only the A6 engines came with the oil cooler.
Old May 8, 2013 | 05:11 PM
DELuth's Avatar
Water Pipe for auto - 19505-PT2-000
Water Pipe for m/t - 19505-PT3-A00
Water Tap for block - 11107-PT2-000
Hose A for cooler - 19521-PT2-000
Hose B for cooler - 19522-PT2-000
Both of those engines used the same cooler, so you should be good to go there.
Old May 8, 2013 | 05:18 PM
Mishako129's Avatar
Neither of those 2 water pipes have the extra water passage for the oil cooler...
Old May 8, 2013 | 05:25 PM
DELuth's Avatar
Oh, I see what you mean! 19505-PT3-A00 listed for everything! hmmm....
Maybe the A/T # will work? Strange. I see why you are frustrated.
Old May 8, 2013 | 05:27 PM
Mishako129's Avatar
I have the A/T one on my car already, it doesn't have any other passage on it.
Old May 8, 2013 | 05:51 PM
DELuth's Avatar
The auto one has a PT2 number. A 91 is showing to use the PT3 number, auto or m/t. If the pipe you have on it now is original, it is supposed to be a PT3.
The one listed for an auto is the one you need.
Old May 8, 2013 | 05:53 PM
DELuth's Avatar
Honda's catalogue is full of errors. Drives me mad!
That pipe is upside down and looks like the wrong one! I dunno dude.
Old May 8, 2013 | 06:03 PM
DELuth's Avatar
At least the manual shows the right one
Old May 9, 2013 | 05:08 PM
Mishako129's Avatar
Wow nobody can find the right part number? Oh well. I am considering ditching the whole thing anyways. What would you guys rather do, install it on your car or sell it? Is it even worth it? I am talking about the OEM oil cooler. I could weld a coolant passage onto my original water pipe but I don't really wanna do that.
What's a going price for an OEM oil cooler anyways? I have the nipple that goes on the block, the coolant hoses., basically everything. I even have two 20 mm nuts to remove the original oil filter stud. All I need is the correct water pipe.
Weld or sell?
Old Sep 21, 2013 | 02:18 PM
MAD_MIKE's Avatar
MM Gruppe B
Mishako, bump this thread with your new one. It's related.
Old Sep 21, 2013 | 02:29 PM
Mishako129's Avatar
Its alright I picked up the water pipe from the junk yard the other week.
Guess I should have just posted my question on here, oops my bad sorry. I am bad at that you guys are right. Need to find my old threads and post all the revelent stuff there!
Old Sep 21, 2013 | 08:06 PM
NZXTInerTia's Avatar
Or maybe create one large build thread instead of spamming the forum every five minutes.
Tonyneedshelp
14
Mar 6, 2012 12:24 PM
EJ8_Man
Oct 31, 2011 03:00 PM
siblues
Jan 22, 2005 02:11 PM
OKSolSi
May 9, 2002 11:03 PM
